How best to deal with NMC SSL certificate expiration
  • How best to deal with NMC SSL certificate expiration
5060
138
Erasmus_apc
Sisko Erasmus_apc
112
marting
Lieutenant JG marting
Lieutenant JG
Posted: ‎2022-03-09 11:30 AM . Last Modified: ‎2025-08-11 03:55 AM
14801
We have several hundred APC devices across many sites and started switching from HTTP/telnet to HTTPS/SSH a while back (apparently two years ago).
What we started seeing recently is not being able to get to certain devices via HTTPS.  Tried both via StruxureWare DCE and a standard browser.
Thankfully, SSH still worked on these devices and I was able to enable HTTP and do some more investigation on this.
It looks like the certificates that were created by the devices when HTTPS was initially enabled had a 2-year lifespan and are starting to expire...
It looks like I can work around this by deleting the certificate which forces creation of a new one on NMC reboot but that one looks to have a lifespan of only 1 year.
Needless to say, doing this process on all our devices once a year is not going to be sustainable.
Has anyone found a good way of dealing with this?
I found this thread about bulk-creating CSRs and then bulk-uploading certs.  Is this the easiest way to deal with this?
Was not expecting to have to go through this type of project 2 years after we enabled HTTPS...
  • Smart-UPS & Symmetra LX-RM
  • NMC
Posted: ‎2022-03-10 01:25 PM
@marting
You should upgrade the cards to firmware 7.0.4 to resolve the issue.
If the UPS are Smart-UPS go to
https://www.apc.com/shop/us/en/products/UPS-Network-Management-Card-v7-0-4-Firmware-for-Smart-UPS-Ga...
If the UPS is a Symmetra 3 phase go to
https://www.apc.com/shop/us/en/products/UPS-Network-Management-Card-v7-0-4-Firmware-for-Symmetra-1-P...
PERI
Crewman PERI
Crewman
Posted: ‎2022-05-27 06:16 AM
In response to RicR
14349
This worked for us:
cd ssl
delete defaultcert.p15
reboot
Replies 9
Matt-B
Lieutenant JG Matt-B Lieutenant JG
Lieutenant JG
Posted: ‎2022-03-09 11:39 AM
14788
The expiration date has since been updated in v7.x firmware to be 2035 for self signed certificates - more info in the KB article here: https://www.apc.com/us/en/faqs/FAQ000233142/
All you would need to do is upgrade the firmware, then delete the cert and reboot the NMC. When the card turns back on, the newly generated certificate will be valid until 2035.
marting
Lieutenant JG
Posted: ‎2022-03-09 02:54 PM
In response to Matt-B
Thanks, that's great news!
I know I can push out the updated firmware via StruxureWare but...  is there any way to automate the deletion of the existing SSL certificate across many devices?
StruxureWare supports running custom console commands across many devices so if there is a console command that could be run to do this, I could do it that way.
Also open to other options!
@marting
RicR
RicR
Cadet
Posted: ‎2022-05-03 12:17 PM
14550
Deleting the Cert and rebooting is fairly simple unless you have 250 devices.  We have both NMC2 and NMC3 devices. Looking for the most efficient way to automate the process as much as possible.  I have been looking at scripting the commands through CLI but having trouble with deleting the existing certificate.
Any suggestions on the best way to update this many devices?
PERI
Crewman PERI
Crewman
In response to RicR
14350
This worked for us:
cd ssl
reboot
marting
Lieutenant JG
Posted: ‎2023-05-22 09:30 AM
In response to PERI
2
11591
Thanks @PERI !
Was able to bulk-deploy that to our devices using the Custom Command function in SNMP Device Configuration in DCE (after upgrading firmware).
EPacey
EPacey
Cadet
Posted: ‎2024-06-24 12:02 PM
In response to marting
6206
Hi Marting,
Could you share the steps you used to bulk-deploy the custom command?
Thanks in advance.
marting
Lieutenant JG
Posted: ‎2024-07-01 09:44 AM
In response to EPacey
In DCE:
  • Device > APC SNMP Device Configuration
  • User Configuration...
  • Select the devices you want to target
  • Click Add Custom Command and add in each of the commands in PERI's post
  • Click Finish to deploy
I would test on one or two devices to make sure you have the process down before mass-deploying.
tcrowe
Crewman tcrowe
Crewman
Posted: ‎2024-07-02 07:57 AM
There are a few ways to deploy SSL certs.
We're using a powershell script via SSH. You'll need the Posh-ssh module.
