Help! Single phase to three-phase converter on UPS output?
  • Help! Single phase to three-phase converter on UPS output?
blackyman7_apc
blackyman7_apc
Cadet
Posted: ‎2021-07-12 12:46 AM . Last Modified: ‎2024-02-14 02:44 AM
4424
Hey team! I have a single-phase output UPS that I need to power a three-phase input DC supply. It's going to cost me way too much to replace either of the units. How practical would it be for me to add a 1-phase to 3-phase converter between my UPS and DC supply? I know I stand to lose ~1/3 capacity on the converter; are there any other considerations I'm overlooking? Do any of you have a good schematic that shows standard converter electronics?
  • Data Center & Facility 3 Phase UPS
Brad_C
Commander Brad_C
Commander
On 12/12/2020 6:42 PM, Mitchel said:
any considerations I might be overlooking.
Voltage. 3 Phase is 120 degrees separated whereas your single phase voltage will translate directly through the converter. If you were in Australia for example, on 230V mains you'd normally have a nominal 415V three phase. Using a converter you get 230V 3 phase. You'll need to look carefully at the output of the converter to make sure it's what you really need. Additionally, the cheap-mid market converters tend to have really poor input power factor with direct rectified mains rather than using a PFC boost converter, so you'll want to make sure the UPS is happy with that.
modesta_apc
modesta_apc
Cadet
The intent is to go with an off-the-shelf item.
The Ultimate Problem I need to solve is as stated: I have a 1 phase output from my UPS, but it needs to supply a three phase load.
Plan: buy a 1-to-3 phase converter to solve the problem. Having never used one before I was looking for a circuit diagram to better understand what I'm putting into my system. Also looking for any practical advice on using a 1-to-3 phase converter - any considerations I might be overlooking.
Thanks!
upsers
Brad_C
Commander Brad_C
Commander
Brad_C
Commander Brad_C
Commander
Posted: ‎2021-07-12 12:46 AM . Last Modified: ‎2024-02-14 02:42 AM
On 5/1/2021 12:35 PM, Patricia said:
What's the probability that it will work completely fine without any issues in it.
About the same probability you'd come back after 24 hours and insert a spam link in your post. Oh, gee. Look at that!
