Posted: 2021-06-28 09:54 AM . Last Modified: 2024-03-15 06:10 AM
Hi All
I just have problem with my UPS SURTD5000XLI .
9RoQBFnZQYcuMGFoXVe9SQ%3D%3D&Rest-Api-Key=d3Bhc3F1aWw6NjM3MzU2MWEtNzYzMC00OTc5LTkyMTAtOTJjYTU0NGEwZWFl.jpeg
it working fine~ 2 year until today when I power on this ups appear red X led and the led in battery grap like this ( not flashing)
1
after use "brain dead" way to reset . it working like normal some minutes then this error come again
and in before(when it working normally) I can't power on this ups when it unplug from wall ( cold start -with battery connect)
So I need send it to repair ?
Thank you!
Posted: 2021-06-28 09:55 AM . Last Modified: 2024-03-15 06:10 AM
Hi Minh,
The sequence of LEDs you have described indicates a High Output Voltage alert. You can try to recover the unit by performing a braindead - if the UPS behavior does not change, I would recommend contacting your local APC Tech support for further troubleshooting.
Hi
Is it possible to include a picture of the display.
Matt
Hi Matt
Because I had remove the ups out of my rack so I cant power on ( cold start ) now
But I have image for you
three leds are on (constant) after push I/test button . same with connect ac line or not
Hi Minh,
