[FYI] - How to run executable in user session from service session 0
  • [FYI] - How to run executable in user session from service session 0
Posted: ‎2021-06-29 05:56 AM . Last Modified: ‎2024-03-13 12:16 AM
Ladies and Gentleman,
I hereby post a solution that will make it possible to run a program in a user session. This might come in handy when you want to interact with your desktop before shutting down your computer by the UPS.
There are 2 files required, which are a .cmd file and a .ps1 file. (.ps1 = powershell script file)(In this example I will use the names calculator.cmd and calculator.ps1)
1. CMD file
The Powerchute software supports the functionality to execute a .cmd file before shutting down the computer. From this file we are going to execute the Powershell script file.
Type/Copy the following code:
@echo OFF
SET ThisScriptsDirectory=%~dp0
SET PowerShellScriptPath=%ThisScriptsDirectory%calculator.ps1
PowerShell -NoProfile -ExecutionPolicy Bypass -Command "& {Start-Process PowerShell -ArgumentList '-NoProfile -ExecutionPolicy Bypass -File ""%PowerShellScriptPath%""' -Verb RunAs}";
Store and save the file at the cmdfiles location.
2. Powershell script file
The powershell script is going to execute the calculator program with the current session ID of the logged in user.
Side note: Microsoft prevented interaction from a service with programs running on the desktop of a user. This has been done from Windows Vista and higher. When shutting down your PC you want to shutdown certain programs, due to session 0 isolation this has be come impossible (well nearly :P).
What is this file going to do? It is going to check if the 'explorer.exe' is running and if so it is going to retrieve its token. Then the script is going to execute your command in the user session. (I know there is more to it but I don't want to explain every little detail because I want you to read/study *cough* copy the script).
$source = @"
using System;
using System.Diagnostics;
using System.Runtime.InteropServices;
using System.Security;
public class ApplicationLoader
    #region Structures
    [StructLayout(LayoutKind.Sequential)]
    public struct SECURITY_ATTRIBUTES
        public int Length;
        public IntPtr lpSecurityDescriptor;
        public bool bInheritHandle;
    public struct STARTUPINFO
        public int cb;
        public String lpReserved;
        public String lpDesktop;
        public String lpTitle;
        public uint dwX;
        public uint dwY;
        public uint dwXSize;
        public uint dwYSize;
        public uint dwXCountChars;
        public uint dwYCountChars;
        public uint dwFillAttribute;
        public uint dwFlags;
        public short wShowWindow;
        public short cbReserved2;
        public IntPtr lpReserved2;
        public IntPtr hStdInput;
        public IntPtr hStdOutput;
        public IntPtr hStdError;
    public struct PROCESS_INFORMATION
        public IntPtr hProcess;
        public IntPtr hThread;
        public uint dwProcessId;
        public uint dwThreadId;
    enum TOKEN_TYPE : int
        TokenPrimary = 1,
        TokenImpersonation = 2
    enum SECURITY_IMPERSONATION_LEVEL : int
        SecurityAnonymous = 0,
        SecurityIdentification = 1,
        SecurityImpersonation = 2,
        SecurityDelegation = 3,
    public const int TOKEN_DUPLICATE = 0x0002;
    public const uint MAXIMUM_ALLOWED = 0x2000000;
    public const int CREATE_NEW_CONSOLE = 0x00000010;
    public const int IDLE_PRIORITY_CLASS = 0x40;
    public const int NORMAL_PRIORITY_CLASS = 0x20;
    public const int HIGH_PRIORITY_CLASS = 0x80;
    public const int REALTIME_PRIORITY_CLASS = 0x100;
    [DllImport("kernel32.dll", SetLastError = true)]
    private static extern bool CloseHandle(IntPtr hSnapshot);
    [DllImport("kernel32.dll")]
    static extern uint WTSGetActiveConsoleSessionId();
    [DllImport("advapi32.dll", EntryPoint = "CreateProcessAsUser", SetLastError = true, CharSet = CharSet.Ansi, CallingConvention = CallingConvention.StdCall)]
    public extern static bool CreateProcessAsUser(IntPtr hToken, String lpApplicationName, String lpCommandLine, ref SECURITY_ATTRIBUTES lpProcessAttributes,
        ref SECURITY_ATTRIBUTES lpThreadAttributes, bool bInheritHandle, int dwCreationFlags, IntPtr lpEnvironment,
        String lpCurrentDirectory, ref STARTUPINFO lpStartupInfo, out PROCESS_INFORMATION lpProcessInformation);
    static extern bool ProcessIdToSessionId(uint dwProcessId, ref uint pSessionId);
    [DllImport("advapi32.dll", EntryPoint = "DuplicateTokenEx")]
    public extern static bool DuplicateTokenEx(IntPtr ExistingTokenHandle, uint dwDesiredAccess,
        ref SECURITY_ATTRIBUTES lpThreadAttributes, int TokenType,
        int ImpersonationLevel, ref IntPtr DuplicateTokenHandle);
    static extern IntPtr OpenProcess(uint dwDesiredAccess, bool bInheritHandle, uint dwProcessId);
    [DllImport("advapi32", SetLastError = true), SuppressUnmanagedCodeSecurity]
    static extern bool OpenProcessToken(IntPtr ProcessHandle, int DesiredAccess, ref IntPtr TokenHandle);
    /// Launches the given application with full admin rights, and in addition bypasses the Vista UAC prompt
The name of the application to launch
    /// Process information regarding the launched application that gets returned to the caller
    public static bool StartProcessAndBypassUAC(String applicationName, string startingDir, out PROCESS_INFORMATION procInfo)
        uint winlogonPid = 0;
        IntPtr hUserTokenDup = IntPtr.Zero, hPToken = IntPtr.Zero, hProcess = IntPtr.Zero;
        procInfo = new PROCESS_INFORMATION();
        // obtain the currently active session id; every logged on user in the system has a unique session id
        uint dwSessionId = WTSGetActiveConsoleSessionId();
        // obtain the process id of the winlogon process that is running within the currently active session
        // -- chaged by ty
        // Process[] processes = Process.GetProcessesByName("winlogon");
        Process[] processes = Process.GetProcessesByName("explorer");
        foreach (Process p in processes)
            if ((uint)p.SessionId == dwSessionId)
                winlogonPid = (uint)p.Id;
        // obtain a handle to the winlogon process
        hProcess = OpenProcess(MAXIMUM_ALLOWED, false, winlogonPid);
        // obtain a handle to the access token of the winlogon process
        if (!OpenProcessToken(hProcess, TOKEN_DUPLICATE, ref hPToken))
            CloseHandle(hProcess);
            return false;
        // Security attibute structure used in DuplicateTokenEx and CreateProcessAsUser
        // I would prefer to not have to use a security attribute variable and to just
        // simply pass null and inherit (by default) the security attributes
        // of the existing token. However, in C# structures are value types and therefore
        // cannot be assigned the null value.
        SECURITY_ATTRIBUTES sa = new SECURITY_ATTRIBUTES();
        sa.Length = Marshal.SizeOf(sa);
        // copy the access token of the winlogon process; the newly created token will be a primary token
        if (!DuplicateTokenEx(hPToken, MAXIMUM_ALLOWED, ref sa, (int)SECURITY_IMPERSONATION_LEVEL.SecurityIdentification, (int)TOKEN_TYPE.TokenPrimary, ref hUserTokenDup))
            CloseHandle(hPToken);
            return false;
        // By default CreateProcessAsUser creates a process on a non-interactive window station, meaning
        // the window station has a desktop that is invisible and the process is incapable of receiving
        // user input. To remedy this we set the lpDesktop parameter to indicate we want to enable user
        // interaction with the new process.
        STARTUPINFO si = new STARTUPINFO();
        si.cb = (int)Marshal.SizeOf(si);
        si.lpDesktop = @"winsta0\default"; // interactive window station parameter; basically this indicates that the process created can display a GUI on the desktop
        // flags that specify the priority and creation method of the process
        int dwCreationFlags = NORMAL_PRIORITY_CLASS | CREATE_NEW_CONSOLE;
        // create a new process in the current user's logon session
        bool result = CreateProcessAsUser(hUserTokenDup,        // client's access token
                                        null,                   // file to execute
                                        applicationName,        // command line
                                        ref sa,                 // pointer to process SECURITY_ATTRIBUTES
                                        ref sa,                 // pointer to thread SECURITY_ATTRIBUTES
                                        false,                  // handles are not inheritable
                                        dwCreationFlags,        // creation flags
                                        IntPtr.Zero,            // pointer to new environment block
                                        startingDir,            // name of current directory
                                        ref si,                 // pointer to STARTUPINFO structure
                                        out procInfo            // receives information about new process
        // invalidate the handles
        CloseHandle(hUserTokenDup);
        return result; // return the result
    public void Execute(string applicationName)
        ApplicationLoader.PROCESS_INFORMATION procInfo;
        ApplicationLoader.StartProcessAndBypassUAC(applicationName, null, out procInfo);
Add-Type -TypeDefinition $source
$obj = New-Object ApplicationLoader
$obj.Execute("calc.exe");
#<- Commands like C:\Utilities\program.exe Flag are also possible.
# If running in the console, wait for input before closing.
#if ($Host.Name -eq "ConsoleHost")
#    Write-Host "Press any key to continue..."
#    $Host.UI.RawUI.FlushInputBuffer()   # Make sure buffered input doesn't "press a key" and skip the ReadKey().
#    $Host.UI.RawUI.ReadKey("NoEcho,IncludeKeyUp") > $null
Save and store the file in the same directory as the .cmd file.
Hopefully, this helps you out. We contacted the tech support of APC for help and they told us they did not support the feature to shutdown programs. (This is in my opinion a HUGE FAILURE).
Good luck!!
Greetings,
Phanvi
  • .cmd
  • apc
  • cmdlet
  • desktop
  • interaction
  • mylittlepony
  • PowerChute
  • programs
  • service
  • session0
  • shutdown
  • windows
Replies 0
