Email Problem
Send InviteCancel
Posted: 2021-06-2803:30 AM. Last Modified: 2024-03-1804:36 AM
Email Problem
Hi All,
I have 722 devices UPS's and power rails distributed all over Australia. I have set up email and I have worked out how to bulk change the config.ini file on each device.
My problem is I would like to know if there is a bulk way to delete the email tick on each notification event without logging into each device separately. After this is done I would enable email on the events that we need i.e. on battery, high temp etc.
