Posted: β2021-06-30 08:31 AM . Last Modified: β2024-03-07 03:02 AM
Hi.
I have 2 Symmetras and have recently started work on configuring the management cards to provide an orderly shutdown and restart. Things I have considered:
* Application servers can shutdown in any order - there are 5 here.
* Database server next.
* Secondary AD domain controller can shutdown next.
* Primary AD domain controller can shutdown next.
* Disk array attached to Primary AD DC can shutdown last.
# Disk array first.
# Primary DC next
# Secondary DC...
# DB server...
# etc.
My questions are:
* What, other than the array, do I need to do to affect this properly?
* I blelieve I would have to time the shutdown of servers individually so I would know how long each takes... Is that a bad idea?
* How long should I let the systems run on battery? 5 minutes, 10 minutes?
* Is there a certain way I should handle the timings?
* Has anyone managed one of these IBM arrays with SNMP or more in particular, managed an exp400 using SNMP? If so how well/poor did it work?
Thanks for any and all advice or pointers with respect to this.
James
Message was edited by: james.bowes
SUA3000RMXL3U is what i needed. but they all use the same network management cards anyway and use the same powerchute software, etc
what model of symmetra is this?
Hi and thanks for the reply.
The Symmetras are 3000XL units. I am still looking into the snmp for the array... The script is interesting however the array only has 2 on/off switches and really, I cannot see how to power it down other than manually.
--james
i am not sure what you mean by "The Symmetras are 3000XL units." We don't have any Symmetras that are 3000VA..?
depends on the design of the switch. if it has a 2 position switch i am not sure how that would work.
Hmmm - it appears I have supplied the wrong model information... The models of UPS are SUA3000RMXL3U. Would it be the SUA3000RM that is the required information?
Thanks in advance.
--james
