Posted: 2021-06-26 12:57 AM . Last Modified: 2024-03-19 02:40 AM
I have a SURT1000XLI. Got it from work. It was used on a piece of decommisioned equipment.
Would like to use at home. Is there a way to easily convert the output to 115? How about the input?
I am hoping it is as easy as moving a jumper somewhere.
Also, could I use it for extended periods, if I add enough battery, or are these things designed to run stuff just long enough to power down safely?
Pete
On 26/3/2020 7:25 AM, peter said:I am hoping it is as easy as moving a jumper somewhere.
No.
On 26/3/2020 7:25 AM, peter said:Also, could I use it for extended periods, if I add enough battery, or are these things designed to run stuff just long enough to power down safely?
It's an XL, so yes it is designed for additional battery.
No.
