Charger Fault & PFC Fault on MGE Galaxy 5000 80KVA
  • Charger Fault & PFC Fault on MGE Galaxy 5000 80KVA
5060
138
Erasmus_apc
Sisko Erasmus_apc
112
Posted: ‎2021-06-26 05:55 AM . Last Modified: ‎2024-03-19 12:28 AM
5144
Hi Team,
We facing a problem on MGE Galaxy 5000 80KVA. the UPS mimic panel indicated "Charger Fault" & "PFC Fault".
As the DCHON board was already replaced we tried to upgrade the control kit (MIZEN, CHAN, GDEN) by a higher technical level kit, but the fault occurred after three days.
Then we exchanged the two MUTON boards to see if there is a faulty in PFC board ( if there is a fault the UPS will indicate "Inverter Fault" instead of "PFC Fault"), but the UPS indicated "Charger Fault" & "PFC Fault" again.
Next step we replaced the (DCHON Ventilation Fan), and this was a most successful stage as the UPS indicated "PFC Fault" after about 2 weeks without "Charger Fault".
Finally, we re installed the old control version but the UPS indicated "Internal CAN Communication Fault" beside "Charger Fault" & "PFC Fault".
Could you please share your experience in this case?
  • Data Center & Facility 3 Phase UPS
It appears this issue could be many different things and may require a service provider to resolve. The response I received was fairly detailed and seemed to indicate only service personnel should take care of this.
Replies 4
I am looking into a reply to help you with this one. 3 phase MGE is not my thing unfortunately.
hai ahmed
checked the u are battery bank ,mostly u are battery one or more open
Posted: ‎2021-06-26 05:56 AM . Last Modified: ‎2024-03-19 12:28 AM
thanks Angela for your appreciated reply.
@weragala: we have already checked the batteries, however thank you for counseling smile
