Cant make SNMP calls after FW upgrade
  • Cant make SNMP calls after FW upgrade
Posted: ‎2021-06-30 05:43 AM . Last Modified: ‎2024-03-08 02:02 AM
1458
Hi, I was wondering if someone could help me with this:
I'm running a AP7953 I've upgraded to AOS 3.67 and APP 3.57 (from memory..not at work), however I'm not getting anything back when making snmp calls - where I had no trouble before,even using numeric id's. Has anyone had this problem?
Regards
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
Sisko
Posted: ‎2021-06-30 05:44 AM . Last Modified: ‎2024-03-08 02:01 AM
That's probably not a good thing. There has to be something there because that's what allows you to gain web/IP access to the PDU to begin with. When you do an "ls -l" what exactly appears? There should be 5 files. Two firmware (AOS and rPDU) files, an event.txt, data.txt and config.ini file.
Replies 8
Thanks I'll give it a go..
I do ftp> ls but can't find any config.ini on the card..
Regards
Message was edited by: moetman
Posted: ‎2021-06-30 05:44 AM . Last Modified: ‎2024-03-08 02:02 AM
Managed to get it going. Reboot got it up.
Regards
TheNotoriousKMP_apc
Sisko
What version of the MIB are you running? Chances are upgrading your MIB may be in store.
I'm using MIB 3.67 - the AOS version is 3.57 and the APP is 3.56
The Mib should be compatible shouldn't it?
TheNotoriousKMP_apc
Sisko
That MIB is pretty outdated.
Here's a link to the new one:
ftp://ftp.apc.com/apc/public/software/pnetmib/mib/391/
Try this and let me know if it works.
Yea - tried that one , I can't understand why it doesn't respond , unless the ftp transfer went wrong, but I can telnet to the PDU, and the SNMP v1 settings are exactly the same as the old FW I had installed.
Any Ideas?
Regards
TheNotoriousKMP_apc
Sisko
FTP into the card, pull you config.ini file. Then reset your card to defaults except TCP/IP. Log out, wait for it to finish booting. Go back and try to pull SNMP values from it again.
TheNotoriousKMP_apc
Sisko
