  • Get started
Brand Logo
  • Get started
  • Community Home
    • By Topic
    • By Topic
      EcoStruxure Building
      • Field Devices Forum
      EcoStruxure Power & Grid
      • Gateways and Energy Servers
      • Protection & Control
      EcoStruxure IT
      • EcoStruxure IT forum
      • EcoStruxure IT™ Advisor CFD
      Remote Operations
      • Remote Operations Forum
      Industrial Automation
      • AVEVA Plant SCADA Forum
      • CPG Expert Forum DACH
      • Machine Automation Forum
      • Modicon PAC Forum
      • PLC Club Indonesia
      Schneider Electric Wiser
      Power Distribution IEC
      • Specifiers Club ZA Forum
      • Електропроектанти България
      Power Distribution NEMA
      Power Distribution Software
      • LayoutFAST User Group Forum
      Light and Room Control
      • SpaceLogic C-Bus Forum
      Solutions for your Business
      Support
    • Geo SCADA Knowledge Base
    • Digital E-books
    • Success Stories Corner
    • All Events
    • Innovation Talks
    • Innovation Summit
    • Let's Exchange Series
    • Partner Success
    • Process Automation Talks
    • Technology Partners
    • EcoStruxure Building
      Remote Operations
    • By Topic
    • By Topic
      • Backstage Access Resources
      EcoStruxure IT
      Remote Operations
      • Remote Operations Blog
      • Industrie du Futur France
      • Industry 4.0 Blog
      • NEMA Power Foundations Blog
      • KNX Blog
      • Digital E-books
  • companyImpact
Cannot seem to set IP address on AP9617 (Smart-UPS 2200)
  • Communities
  • Re: Cannot seem to set IP address on AP9617 (Smart-UPS 2200)
  • Subscribe to RSS Feed
5027
195
Sisko Erasmus_apc
111
TheNotoriousKMP_apc
Sisko TheNotoriousKMP_apc
108
KBBB_apc
Crewman KBBB_apc
Posted: ‎2021-06-30 10:51 PM
474
This was originally posted on APC forums on 12/13/2015
I have attempted to set option 43 with the proper Hex.
I have also attempted to:
arp - s 10.20.1.22 XX-XX-XX-XX-2E-AD
PING -l 10.20.1.22
This AP9617 is refurbished and I have factory reset it.  What could I be doing wrong?
Thank you so much for your help in advance!
K.B.
EDIT: the light on the 9617 port (at the UPS) is Solid Green and blinking Amber
  • address
  • ARP
  • ip
  • network-management-card
  • NMC
  • smart-ups
This reply was originally posted by Bill on APC forums on 12/14/2015
Have you tried to connect to the NMC via serial comm?
You can use a local computer, a computer that connects to the Management Card through the serial port at the Management Card’s UPS to access the Control Console.
1. Select a serial port at the local computer and disable any service that uses that port.
2. Unless an APC smart-signaling cable (940-0024 or 940-1524) is already connected to the selected port, connect the smart-signaling cable that came with the Management Card or UPS to the selected port and to the serial port at the UPS.
3. Run a terminal program (such as HyperTerminal or Putty) and configure the selected port for 2400 bps, 8 data bits, no parity, 1 stop bit, and no flow control, and save the changes.
4. Press ENTER to display the User Name prompt and enter the user name. Default is apc
5. 4. Press ENTER to display the Password prompt and enter the password. Default is apc
6. After you log in choose Network from the Control Console menu.
7. Choose TCP/IP from the Network menu.
8. If necessary, change the Boot Mode setting to Manual.
9. Set the System IP, Subnet Mask and Default Gateway address values.
10. Press CTRL-C to exit to the Control Console menu.
11. Log out (option 4 in the Control Console menu) to have the changes take effect
Replies 2
KBBB_apc
Crewman KBBB_apc
This was originally posted on APC forums on 12/17/2015
Thank you!  I was under the impression that I did not need that cable.. I procured one and I am all set now.
Thanks again!
Kevin
Additional options
