Cannot Upgrade AP9631 with SUMX/AOS 5.0.3 and BootMon 1.0.0
  • Cannot Upgrade AP9631 with SUMX/AOS 5.0.3 and BootMon 1.0.0
Posted: ‎2021-07-01 06:03 AM . Last Modified: ‎2024-03-04 11:52 PM
1444
I'm trying to upgrade an AP9631 NMC (s/n JA1011015845) that currently has SUMX 5.0.3, AOS 5.0.3, and BootMon 1.0.0.
I have tried using the FW_Upgrade_R2.exe tool to upgrade to 6.1.1 / 1.0.2 and after that failed, to 5.1.7 / 1.0.2. In both cases, it fails during the upload of the BoonMon 1.0.2 file at around 27%.
After each failure, I have to pull the NMC out, wait 5-10 seconds, and then I can console in and reset the IP address from 0.0.0.0 by selecting DHCP and rebooting the unit.
I have attached the result.txt file.
Any thoughts on how to resolve this issue?
result.txt.zip
Posted: ‎2021-07-01 06:04 AM . Last Modified: ‎2024-03-04 11:52 PM
Hi Terry,
Your card is in a serial number range where we had a problem with the hardware that prevents an upgrade. It will require replacement and we can do that under warranty for you, technically even though the serial number is out of warranty.
Do you have any other cards with this problem? We'd need to review their serial numbers too. We're looking for anything XX1010-XX10-15. When you have reviewed them, then you can contact technical support via your preferred method and provide them this thread, or let me know and I can get someone to contact you to complete the process for discussing shipping address, etc.
Replies 6
Hi Terry,
Hi Angela,
Thank you for the very prompt response. I do not know of any other cards in the s/n range at this time. I will hold off contacting tech support until we have reviewed our fleet.
OK. Let me know if you have any other questions or issues regarding this topic. cool
Hi Angela - I'm in the same boat as the original poster - unable to upgrade firmware from 5.0.3 / 1.0.0 and my serial number falls into the range you mentioned (only a few off from the OP - must have been mfgd the same day).  How would I proceed in processing a warranty replacement?
Hardware Factory
Model Number:     AP9631
Serial Number:     JA1011015826
Hardware Revision:     05
Manufacture Date:     03/10/2010
MAC Address:     00 C0 B7 51 F1 37
Management Uptime:     0 Days 1 Hour 32 Minutes
Application Module
Version:     v5.0.3
Date:     Aug 6 2009
Time:     21:53:59
APC OS (AOS)
Version:     v5.0.3
Date:     Aug 4 2009
Time:     13:12:44
APC Boot Monitor
Version:     v1.0.0
Date:     Oct 8 2008
Time:     16:03:02
You're in the US, right? We are closed tomorrow and Friday so if you contact support today via phone or email, tell them Angela N said it is OK to process a replacement and refer to article ID FA156377 and they should know what to do. laughing If you're not in the US, then I suppose it will still apply and they can handle it.
Sent this link and your reply via support chat and RMA is processing.  Thanks!
