Posted: 2024-11-05 08:56 AM . Last Modified: 2024-11-05 08:57 AM
Hello, we had a battery leak recently in our Smart-UPS 3000 RM XL. I have included images of the bulging batteries and leak stains inside the frame. I'd like to know the best way to clean up the stains inside the frame before I insert a new set of batteries.
Posted: 2024-11-06 05:59 AM
Baking soda will neutralize the battery acid. Once neutralized use clean water and wipe the entire area clean and let dry.
If the battery cartridge was like this for a long time. You’ll need to open up the top cover of the UPS.
Inspect the entire board for any signs of corrosion! ☝️ Once the new battery cartridge has been installed validate what the charging and float voltage is with a meter at the battery terminals.
Compare that to the LCD / NMC which should be the same. Call out what both indicate along with the uploading the data & event logs for the system. 👍
