Batteries replaced yet still showing "Discharged battery"
  • Batteries replaced yet still showing "Discharged battery"
Posted: ‎2021-06-29 11:27 PM . Last Modified: ‎2024-03-12 12:51 AM
1391
We have a Smart-UPS RT 10000XL.
We had the batteries replaced a few days ago.
It seemed the batteries started charging right away but these messages remained:
"Discharged battery" & "The battery power is too low to support the load, if power fails, the UPS will be shut down immediately".
A while after the replacement the "battery capacity" showed 100% but when I run a runtime calibration it immediately drops to 6-7 %, after some hours it's back at 100% but still messages stay...
Please advice on what could be causing this.
I'll send you some instructions offline to try if the calibration is not working properly.
Replies 7
Would you mind sending me the instructions as well? I'm running into the exact same issue.
I will but I need to know what model of UPS it is and confirm that the batteries have just been replaced because this procedure cannot be done on a UPS with old batteries.
Typically, the calibration should be tried first...
It is a model SURT8KRMXL6U-TF5 and yes, the batteries have just been replaced. I attempted another runtime calibration and the batteries went from 100% charged to 2%, and the Discharged Battery error is up again.
I can confirm that the procedure that was provided worked.
But you indeed need to contact APC for the correct instructions as they are dependent on the UPS type.
Filip
Posted: ‎2021-06-29 11:27 PM . Last Modified: ‎2024-03-12 12:50 AM
Hi Angela,
Can you share the solution for the "Discharged Battery" event in a Smart-UPS RT 10000 XL ?
The event began after change the batteries.
Any advice?
