BR1000G-IN 1 KVA - Active TRIM
Send InviteCancel
If you have APC PCPE / PCSS software installed on a Windows computer system. Check to see if there’s an option to adjust the upper / lower transfer voltage.
Let me know what you see and find out using PCPE / PCSS. 👍
