Send InviteCancel
Posted: 2024-07-1201:29 PM
Smart-UPS SRT 3000 "battery pack incompatible"
So in April I purchased an Smart-UPS SRT 3000 (SRT3000UXI-NCLI). Today, (finally) arrived a pair of 1U battery packs (XBP48RM1U-LI), which at the time, I thought were the right ones.. However, when I connected them all up, it appeared to go through some sort of firmware upgrade, and now the main unit is telling me "battery pack incompatible". Is this because they're not the "XBP48RM1U2-LI" models?..
Posted: 2024-07-1609:14 AM
If the information you’ve provided up above is accurate. You’re correct the extended battery pack you have on site is the wrong one! ☹️
The XBP48RM1U2-LI is the correct extended battery pack for this specific APC UPS Lithium model. You can affirm this in the APC resource link for compatible batteries:
Let me know if you have more questions. If not and this information helped resolve the question please do mark this as a solution to assist the next person asking the same. 👍
