Alternating Cold and Hot Aisles Provides More Reliable Cooling
Send InviteCancel
Posted: 2021-06-2601:06 AM. Last Modified: 2024-03-1902:34 AM
The Uptime Institute's white paper talking about how alternating cold and hot aisles provides more reliable cooling for sever farms. This goes hand-in-hand with APC's cooling philosphy.
Mixing of hot and cold air streams in the data center lowers availability of IT equipment. Returning the warmest possible air to the computer room air conditioners increases the efficiency and capacity of the system. The hot aisle containment system ensures proper air distribution by completely separating supply and return air paths. The hot aisle is sealed off using doors and transparent ceiling tiles that extend the width of the hot aisle. Ceiling tiles are available for 300mm, 600mm, and 750mm wide NetShelter Racks, UPS/PDU, and InRow Cooling products.
Learn more about our hot aisle containment system:
And the corresponding white papers are also attached to help you learn more about this "hot" topic.
The Advantages of Row and Rack-Oriented Cooling Architectures for Data Centers WP #130 & Impact of High Density Hot Aisles on IT Personnel Work Conditions WP #123
Feel free to post your questions or comments.
About The Uptime Institute, Inc.®
Using benchmarking, abnormal incident data, and industry Best Practices collected from members of its knowledge communities, The Uptime Institute, Inc. (The Institute) has distilled uptime management into scientific disciplines and practices which can be confidently applied. The synergy of a knowledge community encourages more to be shared so that more is known, and then there is even more to be shared. This exponential increase in knowledge is facilitated by the Institute and its faculty of Distinguished Fellows. Knowledge community participation directly translates into reduced failure rates and increased organizational effectiveness because managers know where and how to apply resources. The immediate benefit is higher levels of quality performance and customer satisfaction while simultaneously reducing investment and operating costs.
