Posted: 2021-06-28 06:59 AM . Last Modified: 2024-03-18 01:03 AM
Dear Folks,
Can anybody tell me the part number of apc cooling system, i.e. Air Cooled Self Contained System (1Piece), means it has no out door. Cooling capacity is 3 kW and Ducts can be installed to supply and return condenser air.
I am waiting for your support.
Thanks in advance.
Posted: 2021-06-28 07:00 AM . Last Modified: 2024-03-18 01:02 AM
Hello warifir,
I believe what you may be looking for is the ACPSC3500 cooling unit, which can be viewed on the APC website here. This unit has 3.5kw cooling capacity, is self contained, and only requires a single duct for the condenser air. If you had any other questions, on this unit or otherwise, please just let me know!
Posted: 2021-06-28 06:59 AM . Last Modified: 2024-03-18 01:02 AM
Dear L2,
Thanks a lot. Please confirm last thing, that It means if customer wanna purchase ceiling mounted system then with this part number ACPSC3500 it must be mentioned ceiling mounted OR floor mounted. Means the product and part number is same. But it can be used for both scenario whether floor mounted or ceiling mounted. Therefore, with the part number we should mention the application i.e. ceiling or floor etc???
again thanks for good reply.
Hello warifir,
The ACPSC3500 cooling unit indeed does conform to the section you reference, using a similar setup to the "Air cooled self contained system (1 Piece)" floor mounted example. The unit simply has one condenser exhaust outlet that vents out of the room (or into a conditioned drop ceiling). Air for that same condenser section is drawn in from the room. This makes it an easy to deploy and setup unit for a small heat load such as yours.
Hello warifir,
No problem, that's what we're here for! As for your question, the ACPSC3500 is unfortunately not available in a ceiling mount configuration. We do not currently offer a ceiling mount air conditioner unit. The ACPSC3500 is limited to a floor mounted configuration. If there is anything else I can do for you, please let me know.
Dear L2,
Thank u. It is cleared now.
