Posted: ‎2024-05-16 01:40 PM
This worked fine for a few hours - then just randomly shut off - and will come back in about 5 minutes
Posted: ‎2024-05-17 07:59 AM . Last Modified: ‎2024-05-17 08:00 AM
A few questions to answer and consider relating to your problem:
- What does the unit indicate is the last fault?
- What does the unit indicate is the current & percentage? Keeping in mind it should be below 80% 12 (amps).
- What is the unit defined for upper & lower voltage protection? What is the current voltage indicated by the unit now?
- Overload: Has the unit ever declared a overload and tripped the breaker?
Please answer all the questions listed above.
Posted: ‎2024-05-21 04:12 PM
No faults indicated
5% 2.4 amps (approx)
92 Vols low 132 high
no overload - no tripper breaks
I tried the unit again yesterday - powers up - stays on - only now the only 2 left side lights on are POWER ON and LINE OK - the other 3 are not lit
Posted: ‎2024-05-22 01:25 AM
Based on your reply it sounds like the hardware is damaged / defective. You can try defaulting the unit through the menu. I don’t suspect it will make a difference though.
Is the unit plugged directly into the wall outlet?!? Do not use an extension or plug it into another SPD / UPS.
Let me know the above questions and the results. Failing that submit a RMA with APC Technical Support at this number as the unit has a lifetime warranty:
1-888-88APCAV
Please do let us know how everything turns out after the RMA process is completed. 👍
Posted: ‎2024-05-22 06:03 AM
Yes tried a reset to default.
plugged directly into wall.
Posted: ‎2024-05-23 07:00 AM
Contact APC Technical Support to submit a RMA for the unit. Have the serial number and receipt on hand so they can assist in the warranty repair / replacement.
Let us know how things turn out. 👍
