APC AP7901 - A! question
  • APC AP7901 - A! question
Posted: ‎2021-06-28 07:08 AM . Last Modified: ‎2024-03-18 12:49 AM
4468
I purchased a used AP7901 on ebay.  I was not able to get this unit to get a DHCP address.  I opened a serial connection to the unit, assigned a static IP and it still did not respond.
I noticed that I have, under Stat, it shows N? and A!
Is there a way to correct this?  Not sure what to do.
Thanks.
Posted: ‎2021-06-28 07:09 AM . Last Modified: ‎2024-03-18 12:47 AM
Angela,
What is your fee?
Thanks.
Replies 22
Great.  Where do I ship this unit?
I just sent you a direct message.
Thanks.
The first thing we should do is go under System->About System and scroll through that all and let me know what you see. That way, I can verify the current files on the PDU but hopefully we can fix this or do a firmware upgrade if the firmware is part of the problem.
For example:
About System
Model Number      : AP7921
Serial Number     : ZAXXXXXXXXXX
NMC Serial Number : ZAXXXXXXXXXX
Manufacture Date  : 09/08/2005
Hardware Revision : B2
MAC Address       : 00 C0 B7 78 CC F2
Flash Type        : TOS TC58FVM5B2
Press to continue...
Module Information
Description : Rack PDU APP
Name        : rpdu              Type        : StatApp
Version     : 374               Sector      : 16
Date        : 03/13/2012        Time        : 16:16:54
CRC16       : 4D49
Description : Network Management Card AOS
Name        : aos               Type        : APC OS
Version     : 374               Sector      : 47
Date        : 11/09/2011        Time        : 11:45:09
CRC16       : 49C6
Thanks!
Hi Angela.  Here is the info you requested:
        About System
        Model Number      : AP7901
        Serial Number     : ZA0635007831
        Manufacture Date  : 06/08/2007
        MAC Address       : 00 C0 B7 2B 0A FD
        Flash Type        : AMD A29DL322DB
        Module Information
        CRC16       : 4D49
        Version     : 334               Sector      : 47
        Date        : 01/05/2007        Time        : 14:23:44
        CRC16       : 2D13
Thanks. You have a similar issue to what is outlined here -> AP7921 - empty Device Manager
When you assigned an IP address, did the status LED (with the X or checkmark next to it) turn solid green? Is there a link LED present on the network jack?
Feel free to show me the output of your TCP/IP settings screen too. Maybe there is another problem there causing no network access i.e. missing MAC address.
This is under Network->TCP/IP. See below for mine.
        ------- TCP/IP ----------------------------------------------------------------
        Network started. Manual settings are in use.
        System IP       : 10.44.44.131       MAC Address   : 00 C0 B7 78 CC F2
        Subnet Mask     : 255.255.254.0
        Default Gateway : 10.218.44.1
        Host Name       : APC
        Domain Name     : example.com
     1- System IP      : 10.44.44.131
     2- Subnet Mask    : 255.255.254.0
     3- Default Gateway: 10.44.44.1
     4- Boot Mode      : Manual
     5- Advanced...
     - Back, - Refresh, - Event Log
I am thinking we need to hopefully access this over the network and tinker with the firmware application files and we can probably fix it. If we have to do the firmware over the serial cable to fix it, it will just be long and slow.
The status light was green before I set a manual IP.  It is also green after setting an IP.  It does not respond when I try to hit the web server.
Here is the info:
        System IP       : 10.10.199.49        MAC Address   : 00 C0 B7 2B 0A FD
        Subnet Mask     : 255.255.255.0
        Default Gateway : 10.10.199.1
        Host Name       : APC
     1- System IP      : 10.10.199.49
     2- Subnet Mask    : 255.255.255.0
     3- Default Gateway: 10.10.199.1
     5- Advanced...
     - Back, - Refresh
Posted: ‎2021-06-28 07:08 AM . Last Modified: ‎2024-03-18 12:48 AM
Ok, what this tells me is that manual settings are not actually set/in use since it says Network Not Started, maximum retries reached (which relates to DHCP and/or BOOTP). Did you fiddle with the settings on this screen and play around with the DHCP cookie setting?
Here is what I suggest.
Log into it again, confirm it still looks the same as above and that the boot mode still says manual. Then, go back and press Esc until the main menu and press 4 for log out. Then, press the pinhole reset button on the display with a paper clip or similar to force a reboot. Go back to this menu and verify it says at the top "Manual settings in use" or similar. Then once they are, we'd want to try and log into it.
American Power Conversion               Network Management Card AOS      v3.3.4
(c) Copyright 2005 All Rights Reserved  Rack PDU APP                     v3.7.4
Name      : Unknown                                   Date : 01/09/2007
Contact   : Unknown                                   Time : 11:49:21
Location  : Unknown                                   User : Administrator
Up Time   : 0 Days 0 Hours 1 Minute                   Stat : P+ N+ A!
        Host Name       : APC
     5- Advanced...
Still no response from web server.  Network appears to be working as I see the N+, but I still see an app error.
Hmm - do you have it on a peer to peer network directly connected or do you have this on a functional network? Can you reset it to defaults under System->Tools and re-configure? Before that, I'd make sure a proxy server isn't a problem, like in your browser settings. You can also try telnet if you have that capability.
That does look fine above per the screen.
A! means the application is not right and it isn't. Each APC management card has an APC Operating System (AOS) and an application file for what the management card is installed in (APP) - like a UPS, Rack PDU, etc.
Your firmware is mismatched - you should have AOS 3.7.4 and Rack PDU APP 3.7.4 and instead you have AOS 3.3.4 and Rack PDU APP 3.7.4 so hence the A! because AOS 3.3.4 does not recognize APP 3.7.4 and they don't work together. This is probably the result of a botched firmware upgrade previously.
So, we have two options - try what I mentioned first off and let's try to get the networking to work or the other option is to do serial firmware upgrades which might be a little more timely in the long term. Let me know how you'd like to proceed. What we will need to do is load the application file that goes with AOS 3.3.4 to get it back to where it should be, then we can try a firmware upgrade after to AOS 3.7.4 and Rack PDU APP 3.7.4.
Posted: ‎2021-06-28 07:09 AM . Last Modified: ‎2024-03-18 12:48 AM
The botched firmware would have been my fault.  When at first it would not work out of the box, I uploaded the 3.7.4 firmware via serial.  I did not upload the app.  I have just completed an update.  This is where I stand.
I have verified there is nothing blocking communication.  If I plug this same network cable in to a machine, I am able to remote to it without any problems.
        About System
        Module Information
        CRC16       : 49C6
        CRC16       : 49C6
------- System ----------------------------------------------------------------
     1- User Manager
     2- Identification
     3- Date/Time
     4- Tools
     5- RADIUS
     6- Modem
     7- About System
     - Back, - Refresh
Hi Brian,
Can you confirm what you see now - is AOS 3.7.4 active or AOS 3.3.4 - (you can tell by what you see on the top right hand corner of the screen when you log in). Whatever this number is now, you need to load the APP that matches it.
In your latest posts, it looks like you have two AOSs v3.7.4 - if that is the case, I would try to put 3.7.4 rpdu APP on there. It appears 3.3.4 got overwritten.
Let me know if you find anything different. Don't worry - we'll get it going!
        Host Name       : APC
     5- Advanced...
American Power Conversion               Network Management Card AOS      v3.7.4
(c) Copyright 2009 All Rights Reserved
Contact   : Unknown                                   Time : 12:46:54
Up Time   : 0 Days 0 Hours 6 Minutes                  Stat : P+ N+ A-
------- Control Console -------------------------------------------------------
     1- Device Manager
     2- Network
     3- System
     4- Logout
     - Main Menu, - Refresh
Angela,
Like the idiot I am, I jumped the gun and loaded the APP for 3.7.4.  I mis-read your message.  How do I go back down to 3.3.4 for both APP and everything else?  Where do I find the necessary files?
Brian
The initial login screen shows:
User Name : apc
Password  : ***
Name      : Unknown                                   Date : 01/10/2007
Contact   : Unknown                                   Time : 06:47:11
Up Time   : 0 Days 18 Hours 0 Minutes                 Stat : P+ N+ A-
     1- Device Manager
     2- Network
     3- System
     4- Logout
Ok, I would put rpdu v3.7.4 on next and see what happens.
I put 3.7.4 on there.  This is where I'm at:
User Name : apc
Password  : ***
(c) Copyright 2009 All Rights Reserved  Rack PDU APP                     v3.7.4
Name      : RackPDU                                   Date : 01/10/2007
Contact   : Unknown                                   Time : 08:58:47
Up Time   : 0 Days 0 Hours 8 Minutes                  Stat : P+ N? A+
Switched Rack PDU: Communication Established
     1- Device Manager
     2- Network
     3- System
     4- Logout
     - Main Menu, - Refresh, - Event Log
Can't get the network to come up.  Will not get a DHCP address, and when I assign a manual, it does not respond.
Ok, that looks right for the firmware stuff. Now, we need to get the web working - what is the Network set to now - I see N?
Did you want to try DHCP/Manual TCP/IP settings again? Had you tried to reset this to defaults per one of my earlier suggestions (which perhaps wiped everything out)? If not, that would be our next step under the System->Tools menu in an attempt to get the web interface working (or any of the network interfaces).
If web does not work, you could try FTP.
I did a reset.  DHCP does not grab an address.
     4- FTP Server
     5- Telnet/SSH
     6- Web/SSL/TLS
     7- Email
     8- SNMP
     9- Syslog
    10- ISX Protocol
> 1
        Network not started. Currently making a DHCP request...
        * A cookie is required in the vendor options to accept a DHCP offer.
     1- Boot Mode  : DHCP only
     2- Advanced...
Setting a static IP does not work either.  It will not respond to anything.
Under #2 in TCP/IP settings, you do need to probably change the option for the vendor cookie to NOT be required to accept an offer. Then press accept changes at the bottom of that menu and confirm it says success, and then press ESC until you get back to the main menu and log out and let it reboot one more time.
I imagine you are not using or familiar with option 43 for DHCP (called a vendor cookie) - especially if you're using this on a home network or small network. This prevents a lot of users from getting a DHCP address if not set up properly but it can be disabled as I instructed.
If that still does not work, I am not sure what else I can do or what could be wrong with it. I can offer to look at it if you wanted me to look at it and ship it back to me (in Rhode Island @ APC headquarters) but so far, everything sounds goods and looks good in the menu (besides DHCP cookie).
Angela,
What is your fee?
Thanks.
