APC-9210 Password recovery and firmware
  • APC-9210 Password recovery and firmware
5060
142
ijhursh_apc
Crewman ijhursh_apc
Crewman
Posted: ‎2023-05-17 12:59 PM
1017
I know this is old, but it still works and here is the info below, also can i get the last firmware version that was used? Info below.
Hi Bill,
I have 2-APC-9210's, I have tried eprom dump and cannot get in one info is below.
- Model Number : AP9210
2- Serial Number : WA9913001391
3- Hardware Revision : C4
4- Manufacture Date : 03/22/1999
5- MAC Address : 00 C0 B7 92 4C 38
6- Firmware Revision : v1.1.1
7- Outlet State (Hex) : 00
8- Receive Setup Packet
9- Transmit Setup Packet
10- Unit Self Test
11- Dump EEPROM
12- Flash Status Green
13- Flash Status Red
14- Turn Status OFF
15- Set IP Address : 192.168.7.210
16- Set Subnet Mask : 255.255.255.0
17- Set Default Gateway : 192.168.7.1
18- Reset PDU Controller
19- Start Factory Testing
20- End Factory Testing
21- International Type : A
22- Language Type : A
hopefully you are still there and can help me!
thx
Jim
padred727_apc
Ensign padred727_apc
Ensign
Posted: ‎2023-05-19 09:52 AM
I wrote this password generator a while ago.  It should handle all your future needs but I already generated your passwords from the info you gave above.
WA9913001391
Login(lowercase): apc
Your Password is(uppercase): 1247>7^IBC<?
You only listed the info from one device but you can generate the other with the tool below.
https://padre-d.com/apc-masterswitch-pass-gen/
padred727_apc
Ensign
WA9913001391
ijhursh_apc
Crewman ijhursh_apc
Crewman
Posted: ‎2023-05-24 06:39 AM
that did the trick, thank you!
