AP9641 and AP8958 config.ini Configuration file warning when setting static IP
Send InviteCancel
I get "Configuration file warning: Invalid value on line 18." for each line, aside from the ipv4 line.
When I include the
Override=MacAddressHere
line, all lines are properly accepted and the static IP is set. I don't currently pull the MACs when the config.ini file is generated, so adding that adds a lot of complexity. Is this a requirement or potentially a bug?
I've tested on AP8958 firmware 2.5.0.6 as well as 1.2.0.4 with no change.
