AP9631 v6.5.0 will not send email with SSL/TLS enabled
  • AP9631 v6.5.0 will not send email with SSL/TLS enabled
pgpc_apc
Crewman pgpc_apc
Crewman
Posted: ‎2021-06-30 12:26 AM . Last Modified: ‎2024-03-11 04:07 AM
4379
We have an AP9631 NMC installed on a SMX2200RMLV2U.  The NMC successfully authenticates and sends emails through Rackspaces's SMTP relay at secure.emailsrvr.com, port 587, with SSL/TLS set to Never.  When SSL/TLS is set to If Supported or Always, no email is sent and the NMC GUI shows the Last Server Response as 220 2.0.0 Start TLS.  Wireshark, however, shows that the SMTP relay and the NMC continue communicating after the relay sends the Start TLS command.  Specifically, the NMC sends a TLSv1.2 Client Hello, the relay responds with a TLCv1.2 Server Hello and then the relay and the NMC exchange about 10 tcp packets before their communications cease.  Scanning the relay and the NMC with NMAP shows they both support TLS 1.0/1.1/1.2 and they have 10 ciphers in common.  I would be grateful if someone could help me get the NMC to send emails through the Rackspace relay with SSL/TLS enabled.
I would be very much interested in a solution, too.
Replies 7
Can you please share the solution, how did you made it to work ?
I am having similar issue.
Jerry95
Jerry95
Cadet
Posted: ‎2023-05-09 02:45 PM
As would I!
Shaun
Commander Shaun Commander
Commander
Posted: ‎2023-05-09 03:04 PM . Last Modified: ‎2023-05-09 03:10 PM
Hi All,
I've seen an issue where the NMC2 (AP9630,31,etc and embedded relatives.  Firmware 5.x.x - 7.x.x) doesn't have enough memory to reassemble larger certificate chains - where the server presents not only its own certificate, but also that of its CA, and sometimes an intermediary CA or two.  The trend towards larger (4096bit) RSA keys exacerbates this behavior as it leads to larger certificates - so the less certificates we can fit in the chain before we exhaust the space.
The symptom for this is that in Wireshark we can see see the client hello, then the server hello, and then when we expect the server to send its certificate, we see an exchange of TCP Window Full (or ZeroWindow) messages.
The last message logged by the card is less useful for this, as any errors in establishing a TLS session will result in the same last message - the card sends STARTTLS, the server replies 220 Start TLS (or Proceed TLS, or similar - the server can put any text after 220, but it'll usually hint at TLS).  For Implicit TLS (port 465), TLS is established before any SMTP traffic, so no last message is logged.  So these particular messages don't really narrow down why TLS failed - making the Wireshark steps incredibly useful.
There's no real resolution available for this, as we can't add more memory to the card.  A common workaround is to relay via an intermediary mailserver which presents a certificate without a CA chain (or with a simpler chain).  Alternatively, the newer AP9640/41 have more hardware resources so shouldn't hit this issue.
dconley_apex
dconley_apex
Cadet
Posted: ‎2025-06-23 11:28 AM
1160
I know this is a year old, but I'm running into the same issue. Microsoft has already announced they will be sunsetting Basic SMTP in the near future
https://techcommunity.microsoft.com/blog/exchange/exchange-online-to-retire-basic-auth-for-client-su...
To prepare, I am testing a supported solution, HVE.
https://learn.microsoft.com/en-us/exchange/mail-flow-best-practices/high-volume-mails-m365#use-follo...
Is it true the AP9631 does not have enough RAM to handle the long certificate chain? Would like to know if anyone else had success with this. Thanks!
Kirk
Posted: ‎2025-06-24 05:50 AM
In response to dconley_apex
1155
I suggest you start off by updating the NMC to the latest v7.2.0 firmware branch and see if anything changes.
If not, it’s time to invest in a AP9640 / 41 NMC.
I have thousands of the legacy AP9630, 31, 35’s still in production and all can send email using gmail, GMX, etc - for now.
Questions Ask . . . 👍
dconley_apex
dconley_apex
Cadet
Posted: ‎2025-06-25 09:22 AM
In response to Teken
I have updated to the latest NMC firmware revision, still no joy. I will look at having these rotated out and potentially use a local SMTP relay in the meantime. Thank you!
