ACRD100
Send InviteCancel
Posted: 2025-08-0706:43 AM
ACRD100
I have several ACRD100 around the US. With firmware
Network Management Card AOS v3.9.2 ACRP-TK APP v3.7.6
When we connect to the unit via the web, there are no errors. However, EcoStruxure IT notified us with the following:
Temperature sensor "Unit Suction Air Temperature" on device "SRM01-AIR-CON-IDF-04" at 11.9 °C / 53.42 °F is below the threshold "AMER-Temperature Alert 80 or more" of 12.7778 °C / 55 °F
Posted: 2025-08-0705:27 PM
Perhaps someone has set a threshold on that sensor's reading within EcoStruxure IT. This would explain why the device itself doesn't show an alarm. Possible reasons I can think of for creating such a threshold could include:
to implement a conservative early warning before the point at which the ARCD itself considers there to be a problem
to provide an independent warning threshold which does not have an operational impact on the ACRD
perhaps the ACRD does not alert on this particular sensor natively
In any case, there may be a legitimate reason why the threshold was set. I suggest trying to understand who did it and why, before making changes.
