Posted: 2021-06-28 04:37 AM . Last Modified: 2024-03-18 04:17 AM
I am getting a compensating for high voltage on only 1 unit in my facility. but the voltage is not exceeding the threshold of 127.
thoughts?
0x010D
Serial Number :
Device Serial Number :
Date : 04/23/2016
Time : 22:29:37
Code : 0x010D
Posted: 2021-06-28 04:37 AM . Last Modified: 2024-03-18 04:16 AM
Alan,
127 is a low setting and I see that there are a few entries in the data log at 125.19 so it is possible the voltage bumped up higher. Set the threshold to 130 and monitor it. That should resolve the issue.
Alan,
What is the exact model Smart-UPS? You will find the information on the bar code stick on the back of the unit.
Also, is there a network management card in the UPS? If there is it would be helpful to review the data and event logs.
serial number ZA1544070185
device serial 3S1550X01309
its a UPS 1000/1500VA
Alan,
Is there a network card in the Smart-UPS. It would be helpful to see the event and data logs. Also, what is the exact model number? Examples: SMT1000, SMX1000
Notice the threshold isn't passing the 127 and it triggers high voltage.
Alan,
Posted: 2025-11-12 11:55 PM
Hi, I have the same issue.
I can find the Output threshold setting under Configuration > Power Settings
However, I cant find the Input setting anywhere.
Can you point me in the right direction pls?
