Battery
UPS Status
  • EcoStruxure IT Help Center
  • SmartConnect
  • UPS monitoring
  • UPS Status
  • Battery
  • UPS Warranty
  • Battery
  • Operating Mode
  • Control
  • Diagnostics
  • UPS Profile
  • Network
  • Active Events
  • UPS Status page - Web Portal
  • Device
  • Firmware
  • Delete your Device
  • UPS Warranty
  • Battery
  • Operating Mode
  • Control
  • Diagnostics
  • UPS Profile
  • Network
  • Active Events
  • Device
  • Firmware
SmartConnect Support
Request Support
Back to UPS Status
Battery
Commander CDiggin Commander
‎2024-03-11 08:54 AM
Last Updated: Lt. Commander LFleming Lt. Commander ‎2025-01-15 12:49 AM
This section describes the status of the UPS battery.
Status
Description
Runtime
The number of minutes the UPS can support the connected load. This is displayed when the UPS is on line and on battery.
Charge
The percentage of the battery capacity that is available to support the load.
Temperature
The ambient temperature near the UPS battery. Improving airflow and cooling of the UPS can extend battery life.
Replace By
The date of expiry of the Battery. If your UPS battery is due to expire, visit www.apc.com or your reseller partner to buy a replacement battery.
If configured, your reseller will be notified when your UPS battery is due to expire.
Set Battery Install Date
Set the date of battery installation via the cloud when a new battery is installed in the UPS. The UPS calculates the 'Replace By' date of expiry based on the battery installation date. You can also set the date of battery installation via the UPS display.
​If the battery install date is not reset during battery replacement, the UPS may send battery replacement notifications. Set the date via the cloud to avoid on-site configuration at the UPS display.
  • SMARTCONNECT
