Modifying thresholds
Threshold Alarm Configuration view
  • EcoStruxure IT Help Center
  • DCE alarm configuration
  • Threshold Alarm Configuration view
  • Modifying thresholds
  • Mark as Read
  • Modifying thresholds in the Alarm Configuration pe...
  • Delete Thresholds option
EcoStruxure IT Support
Request Support
Back to Threshold Alarm Configuration view
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
All thresholds use the same basic procedure and displays to modify threshold settings.
Note
The same displays are used to modify the threshold settings regardless of whether you select:
  • Edit Threshold, a right-click option in the Alarm Configuration perspective.
  • Edit Alarm Configuration, a right-click option in the Active Alarms view in the Monitoring perspective.
Modifying thresholds in the Active Alarms view
  1. In the Active Alarms view in the Monitoring perspective, select an alarm, and right-click to select Edit Alarm Configuration.
  2. Select This Instance to modify the threshold on the device reporting the selected alarm only, or select All Instances to simultaneously modify the threshold on every device on which it is defined, regardless of whether those devices are currently reporting an alarm.
  3. Click OK.
