Modifying thresholds in the Alarm Configuration perspective
Threshold Alarm Configuration view
Send InviteCancel
In the Alarm Configuration perspective, select a device group, device, or threshold, right-click to select Edit Thresholds, and select the threshold type you want to modify from those defined for the selection.
Note
If you selected Other Numeric Sensors or Other State Sensors to modify multiple thresholds simultaneously, the unit of measure for all selected thresholds must be the same.
In the "Edit Thresholds" display, define the threshold settings, and click OK.
