spacelynk application
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • spacelynk application
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
mostafa_ramadan
Ensign mostafa_ramadan
Ensign
Posted: ‎2024-07-03 06:28 AM . Last Modified: ‎2024-07-14 11:38 PM
1833
I always use wiser for KNX app to control spacelynk device as local device but this days application not longer available, i try wiser KNX but can't read spacelynk device.
What should i do to fix that issue?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
FZetina
Commander FZetina Commander
Commander
Posted: ‎2024-10-09 11:29 PM
@mostafa_ramadan
Following your question above, in case you're not yet aware, you should now also be able to use the new Wiser KNX App with spaceLYnk controllers (as long as the App is available in your country).
Fernando
Fernando Zetina
Replies 5
Thomas_Rohde
Sisko
Posted: ‎2024-07-04 12:41 AM . Last Modified: ‎2024-07-04 12:43 AM
2
1802
Hello Mostafa_ramadan,
I understood that you just want to use it locally in your network.
But is the device still connected to the internet or not?
If it is connected to the internet than we may need to check some details to be able to use the new Wiser KNX App.
If it is not connected to the internet ... then we cant use the Wiser KNX App as such.
Would be a solution to create just an Icon (which looks like an App / which is at the end just a full screen browser) on the dedicated mobile devices?
Kind regards
Thomas
Application Design Engineer
mostafa_ramadan
Ensign
Posted: ‎2024-07-04 10:27 PM
1788
Hello Mr. Thomas,
Yes it connected to Internet
Thomas_Rohde
Sisko
Posted: ‎2024-07-04 11:32 PM
Ok, device is connected to the internet and you tried already to use the new Wiser KNX App which didnt worked.
Can you please share the blocking point you faced?
Do you have the latest FW installed on the device?
Do you have all apps on the latest status?
I recommend to mark by all apps to update them automatically to avoid problems in terms of incompatibility between the mobile app and local apps of your spaceLYnk.
Kind regards
Thomas
Neskettani
Administrator Neskettani Administrator
Posted: ‎2024-10-09 07:28 AM
Hello @mostafa_ramadan  have you found a solution to your problem?
Nesrine Kettani
Marketing owner of Digital Energy Community
FZetina
Commander
@mostafa_ramadan
Fernando
Fernando Zetina
