Regarding Homelynk (Wiser for KNX) mobile application
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Regarding Homelynk (Wiser for KNX) mobile application
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-10-08 10:29 PM
1026
For Homelynk mobile application, is there a possibility to set a code lock / password for control in different areas. For example if there are two floors in a home, can we have separate passwords to access each floor?.
  • Wiser for KNX
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2024-10-09 06:38 AM
you can do access control in configurator for the touch and tablet. On the mobile app I don't think so cause it s link to an email. Maybe replace mobile app by direct touch pro with nat redirection.
Smarthome & Smartbuilding Expert
FZetina
Commander FZetina Commander
Commander
Posted: ‎2024-10-09 11:25 PM
990
@Hurr
Besides the workaround proposed above, for your information, in the next release of the App coming in 1-2 weeks, there is the option when sharing a home to define to which rooms that other account would have access. So consider this maybe you can also set it up in a way to achieve your objective.
Fernando
Fernando Zetina
domotiqa
Lt. Commander
FZetina
Commander
991
@Hurr
Fernando
Fernando Zetina
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-10-10 09:16 PM
Sounds good!
The app upgrade with definition to room access should solve the problem.
@Domotica your suggestions are also noted.
Thank you all for the inputs.
