Wiser knx AC HVAC control modes
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser knx AC HVAC control modes
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Simone.mm
Simone.mm
Cadet
Posted: ‎2024-01-27 09:25 AM . Last Modified: ‎2024-07-14 11:41 PM
1501
I need to show Air conditioning Hvac control modes (heat, cool, fan only, dry) in the new wiser knx app. Is there a way to do this? The thermostat widget doesn't seem to support this.
Appreciate any help!
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Mobile App
  • Wiser for KNX
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2024-02-02 12:33 AM
1412
It can help you this documentation, where mandatory variables are:
https://www.productinfo.schneider-electric.com/wiser-knx/0000956364-wiser-knx-aug/English/Wiser_KNX_...
Also the full guide here:
Wiser KNX Application User Guide Online
or pdf
Wiser KNX Application User Guide pdf
Replies 4
FZetina
Commander FZetina Commander
Commander
Posted: ‎2024-01-30 12:50 AM
1
1443
Hi Simone
In Touch, One of the Thermostat Widgets available should support totally or partially those modes. In The Thermostat Widget you have 4 different Modes, and the option to configure your Fan speed. In the next release of the Touch and mobile App that we're about to launch in a few days, we have improved this Widget and the user will now also have the option to define custom Modes:
Once those changes have been done in Touch they will be also available and reflected in the App.
Once available, please try those.
Fernando
Fernando Zetina
simone-muscat
simone-muscat
Cadet
Posted: ‎2024-02-01 04:09 AM
Thanks for your reply! Will this be a firmware upgrade of the homelynk or the app? i am asking to know what to look out for.
Simone
esteve_budia
Lieutenant
1413
or pdf
simone-muscat
simone-muscat
Cadet
Posted: ‎2024-02-08 01:15 PM
Hi, Thanks, the document is certainly helpful, however note that the document does not as yet include how to handle an Airconditioning system with modes Cool, Heat, Dry, Fan which are standard modes. I am looking forward to the update as mentioned by Fernando.
