Linking/Merging 2 Wiser sub systems into one
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Linking/Merging 2 Wiser sub systems into one
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Daniel.Asgari
Daniel.Asgari Cadet
Cadet
Posted: ‎2024-02-14 05:06 AM . Last Modified: ‎2024-07-14 11:40 PM
1344
Hello all,
I have a residential customer who has recently purchased 2 apartments that are next to one another.
We have a deployed SE knx system and wiser in each apartment, the customer has re modeled the apartments partition and joined both apartments together to make one very large apartment.
I have been asked to provide a solution to bring the 2 together so they can use one gui / app. What would be the best method for the Wisers? Does the wiser support master / slave config?
Current methods in my mind are either,
Bring both together via IP - which I would prefer
Bring both bus lines together and omit one of the Wisers (as the apartments use very similar ets projects, all device types and locations will have same phy addresses in both apartments)
Your input is appreciated
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2024-02-15 06:31 AM
1
1303
Hi Daniel,
let me contact you directly to exchange more in detail about the given situation in your project.
I will share later on here the solution we took, as it could be interesting for other user of this forum also.
Kind regards
Thomas
Application Design Engineer
Replies 4
Thomas_Rohde
Sisko
1
1304
Hi Daniel,
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2024-02-16 04:49 AM
Hi Daniel,
as spoken today. Proposal is to:
- Link both W4K via LAN.
- keep one W4K as a kind of IP-Router. (maybe do a factory reset and upload the final ETS-Project).
- Group-Addresses needs to be adapted according to the new rebuilted rooms.
- Enrich the Touch-Visu of the main W4K with the new rooms and adapt the ones which get enlarged.
It is a pretty nice example for the use of KNX. Just some minor SW-Changes to realize!
Flexibel reaction on requests of the new owner possible.
Kind regards
Thomas
Coppo
Lt. Commander Coppo Lt. Commander
Lt. Commander
Posted: ‎2024-02-18 03:42 PM
I thought this was only available via the cloud linking of 2 Wiser gateways?
Thomas_Rohde
Sisko
Posted: ‎2024-02-18 11:55 PM
Hi Coppo,
yes, you are in principle correct. In case both Wiser for KNX would be seperately available to control parts of the flats.
But it doesnt make sense in this case as both seperate flats will be merged to one big flat.
So there is only the need to keep one as the main controller (control of the new rearranged flat) and the second one acts only as a kind of IP-Router.
Which makes the bridge between the former seperated KNX networks.
Kind regards
Thomas
