Wiser for KNX & SpaceLogic KNX Touch IP 7 Inch Connection
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser for KNX & SpaceLogic KNX Touch IP 7 Inch Connection
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Etis
Etis
Cadet
Posted: ‎2024-10-03 06:39 AM
997
There are detailed documentations on how to program "Wiser for KNX". But i couldnt find any information on how to make the connection between my Wiser for KNX (LSS100100) and Touch Panel (MTN6260-7770).
Do i connect Modbus connections of WiserForKNX to Touch Panels' A and B?
How do i configure the touch panel to show the visualization of the WiserForKNX?
  • Wiser for KNX
FZetina
Commander FZetina Commander
Commander
Posted: ‎2024-10-03 11:22 PM . Last Modified: ‎2024-10-03 11:22 PM
Hi
The Touch screen is not connected physically to the controller, the connection is done wireless. Once the Touch screen is connected to the Power supply and switched on, you can follow the configuration steps described in the user guide (You can find it here). You will need to connect the Touch screen to your WiFi and then enter the IP of the controller, username and password and default URL (It could be set for example to show only the Touch visualization or any other page of the controller).
Fernando Zetina
FZetina
Commander
Hi
Fernando Zetina
