Timer program for heat pump motor
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Timer program for heat pump motor
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2021-07-15 10:52 PM . Last Modified: ‎2024-07-14 11:46 PM
774
Hi, we installed Master MTN 6705-0008 and connected motor load through contactor.
 Control given in push button pro keypad.
Client need: they want to on motor in switch, after some time (ex: 5mins) it should switch off automatically without any manual operation.
I tried in parameters by giving on delay and off delay but not going off automatically after some time
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2021-07-15 11:37 PM
Hello Balaraju,
Alexander is correct. For your needed functionality the staircasetimer is the correct solution.
You have been already on the right track as you can see in the pictures below.
Kind regards
Thomas
Application Design Engineer
Alexander_Efremov
Alexander_Efremov Schneider Alumni (Retired)
Posted: ‎2021-07-15 10:55 PM
770
You can use Staircase timer function in this case.
Best regards,
Posted: ‎2021-07-15 11:33 PM
Kindly share if you have done with parameters settings
Thomas_Rohde
Sisko
Hello Balaraju,
Kind regards
Thomas
