Bellpush function
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Bellpush function
Thomas_Rohde
Sisko Thomas_Rohde Sisko
128
Erwin-vd-Zwart
Sisko Erwin-vd-Zwart Sisko
56
Heribert_Dölger
Lt. Commander Heribert_Dölger Lt. Commander
30
FZetina
Lt. Commander FZetina Lt. Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2021-07-26 01:51 AM . Last Modified: ‎2024-07-14 11:46 PM
348
Bellpush function
Kindly suggest me the bell push function in schneider pushbutton MTN617419 parameter setting
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Erwin-vd-Zwart
Sisko
Posted: ‎2021-07-26 02:26 AM
Set the selection of function to "Edges 1 bit, 2 bit(priority), 4 bit, 1-byte values" and set under Push-button x: (Object A) -> Object A 1 bit, Action on Operation "sends 1", Action on release "sends 0"
Erwin-vd-Zwart
Sisko
Thomas_Rohde
Sisko
Posted: ‎2021-08-10 01:38 AM
Hello Pavankumar-kulkarni,
is it working now?
If yes please press "Accept as solution" by the answer from Erwin.
Kind regards
Thomas
Application Design Engineer
