Multi touch as RGB scenes
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Multi touch as RGB scenes
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-07-07 03:49 AM . Last Modified: ‎2024-07-14 11:46 PM
959
Hello
I use the MT as an RGB Scene,  and I do 9  colors scenes using a script.
but I notice that when I rotate the marking point from end to end or if I make more than one step I receive multiple values from the Color scene object (each step send a different value) and this make the Led Driver act in a wrong way.
So how to make the MT send the last value, or how to over come this using a Script
regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2021-07-14 02:09 AM . Last Modified: ‎2021-07-14 02:10 AM
940
I don't think you can change the behavior of the MTP as it will send his value on each step made..
So the only way to control this is in your script, not perfect but it might do what you need..
If you add a delay before sending the value between each step you might reach what you need..
Add this and copy your current script after the os.sleep(), keep the rest unchanged
previouspid = storage.get('PID:' .. _SCRIPTNAME)
storage.set('PID:' .. _SCRIPTNAME, os.getpid())
if previouspid then
os.kill(previouspid, signal.SIGKILL)
end
os.sleep(3)
-- Put here your normal script and optional adjust the delay
storage.delete('PID:' .. _SCRIPTNAME)
Replies 5
Thomas_Rohde
Sisko
Posted: ‎2021-07-13 11:34 PM
951
Hello Nasser_ic-Syste,
sorry for the late reply! Can you share more information?
What kind of script you are using? Please share as well your ETS-Project.
Kind regards
Thomas
Application Design Engineer
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-07-14 01:58 AM . Last Modified: ‎2021-07-14 02:04 AM
948
Hello @Thomas_Rohde
I can share screenshots from the ETS and here you are:
The point I mean shown clear in the group monitor
While the script will send the color regarding the scene value as mentioned here on page 27
https://download.schneider-electric.com/files?p_enDocType=System+user+guide&p_File_Name=MTN621x-0310...
While first I used an event-based script, but after I notice this behavior I use resident script instead!
Note: I use DALI RGBW DT8,
Best Regards,
Erwin-vd-Zwart
Janeway
941
if previouspid then
end
os.sleep(3)
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-07-14 02:18 AM
937
Thank You @Erwin-vd-Zwart
I Will Try your script, and I have no doubt that it will work fine 🙂
BR
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-07-14 02:27 AM
You need to use it as event based
