The KNX Spacelogic Line Coupler MTN6500-0101
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • The KNX Spacelogic Line Coupler MTN6500-0101
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-08-08 03:10 AM
1362
Hi Everyone,
The space logic KNX Line Coupler MTN6500-0101 blocks application download from ETS to individual devices across the KNX lines specially while downloading from the Main line to the Sub line. Even the earlier versions of this KNX coupler had same issue. We normally use KNX-USB interface MTN6502-0101 for application downloads from ETS5 and always we have to disconnect the KNX coupler to avoid application download failure. It is time consuming to always remove the KNX coupler connections and connect the KNX USB-interface to the sub-line directly to enable smooth application download. Can anyone advise a solution to overcome this difficulty?
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2024-08-09 01:08 AM
Hello Hurr!
Can you please check the following parameter. And if "enabled" please try to disable it.
Kind regards
Thomas
Application Design Engineer
Replies 5
Thomas_Rohde
Sisko
Hello Hurr!
Kind regards
Thomas
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-08-12 08:49 PM
1290
Hi Thomas!
Disabling the setting worked with one coupler device in the network.
I still need to check the result with multiple couplers in the network. Hopefully it will work as well.
Thanks!
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2024-08-24 01:29 AM
Hi Hurr,
It might sound silly to you, but check that the individual address of all KNX Couplers is set correctly and that the address of the interface it is using is consistent with its position in the topology.
Ahmed_Tolba23
Lieutenant | EcoXpert Master Ahmed_Tolba23 Lieutenant | EcoXpert Master
Posted: ‎2025-07-08 03:06 PM
635
I have the same case
I would like to inquire about the importance of configuring the individual address of the USB interface when it is connected to a sub-line.
Is it necessary to change the USB interface’s individual address to match the addressing scheme of the sub-line, or is it acceptable to leave it at the default address (15.15.255)??
note that : I use USB as portable Device so i change the location according to the location of the work (sub Lines)
Lt. Commander
Posted: ‎2025-07-10 12:56 AM
It is mandatory. During the download, a bidirectional exchange of telegrams takes place between ETS and the device being downloaded. If the communication interface uses the individual address common to all KNX devices, the response telegrams may not reach it and could completely invalidate the configuration.
