Widget creator
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Widget creator
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Elettrosecurity
Crewman Elettrosecurity
Crewman
Posted: ‎2025-07-02 12:48 PM
730
Widget creator
i have create one widget with widget creator, but i don't see it in wiser app on my Iphone.
the widget created don't work on telephone app?
thank's
Stefano
Elettrosecurity
  • Mobile App
  • Wiser for KNX
Erwin-vd-Zwart
Janeway
Posted: ‎2025-07-03 09:07 PM . Last Modified: ‎2025-07-03 10:31 PM
@Elettrosecurity
That is correct, the custom widget is not supported in the App, in Touch Config is a tab called “App compatible”, those should be used for the App.
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-07-04 02:16 AM
Correct @Elettrosecurity
Custom widget are not (yet) visible within the Wiser App
Replies 5
ratorg
Ensign ratorg
Ensign
Posted: ‎2025-07-03 03:13 PM
See this help section:
https://www.productinfo.schneider-electric.com/wiser-knx/0000956364-wiser-knx-aug/English/Wiser_KNX_...
Only supported widgets appear in the Wiser app.
Erwin-vd-Zwart
Janeway
@Elettrosecurity
Lt. Commander
Elettrosecurity
Crewman
Posted: ‎2025-07-04 08:55 AM
hi,
ok the widget creator is not compatible with app, but what if i want to create a widget for app that makes lists with predefined 2-byte values? (for split Daikin modbus) example:
0 | FAN
1 | RISCALDAMENTO
2 | RAFFRESCAMENTO
7 | DEUMIDIFICAZIONE
the number is the 2-byte value that i send to modbus for set split Daikin
Erwin-vd-Zwart
Janeway
Posted: ‎2025-07-06 11:29 PM . Last Modified: ‎2025-07-06 11:32 PM
@Elettrosecurity
The only thing you can do is use the available widgets to create something or contact your local product manager to request a enhancement ..
Another option is to use a app widget (if any is usable for your input function) and convert the output of that widget via script into your desired values.
