Dears,
Can someone explain how can we integrate Samsung SmartThings with Wiser for KNX ? and if there is Integration Guide PDF or not,
Kind Regards,
Yes it’s possible, i have a rudimentary script that communicates with my SmartThings but it has to be finalized further, there is no integration guide for this..
I can share the script later this week as I’m traveling..
Here is a sample of the userlib for a get request:
https = require('ssl.https')
json = require('json')
ltn12 = require('ltn12')
--https://account.smartthings.com/tokens
token = 'put here your token from above URL'
function GetRequest(req)
tbl = {}
res, code = https.request({
url = 'https://api.smartthings.com/v1/' .. req,
method = 'GET',
headers = {
['authorization'] = 'Bearer ' .. token,
['content-type'] = 'application/json',
sink = ltn12.sink.table(tbl),
if res and code == 200 then
return json.pdecode(table.concat(tbl))
end
end
And with event/resident script you can request your devices or the status of a device:
require('user.smartthings')
log(GetRequest('devices'))
log(GetRequest('devices/602311d8-6a34-3d7d-af34-9d0cf2a70597/status'))
Hello TechWhiz123!
Is this topic solved?
If so ... please mark the answer from Erwin as solved
