Spacelynk LSS100200-Automations
SpaceLogic KNX Forum
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Spacelynk LSS100200-Automations
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_DΓΆlger
Commander Heribert_DΓΆlger Commander
31
Back to SpaceLogic KNX Forum
prabhuknx1
Crewman prabhuknx1
Crewman
Posted: β€Ž2025-09-27 01:41 AM
638
Dear Sir,
I am Prabhu francis from Singapore.
For current project we are using KNX RF sensor in office. Client requirement to lock the sensor function at 8am to 6am Lights remain always ON.Usually we prefer MTN630919 which easily done locking function and scheduling on Spacelynk.
Right now we are using different type of sensor which could not make it. We have already done in scripting-resident based works fine. But we see the option in automations we already done the settingt but it doesnot execute.
 I have attached image screenshot whether i am making any mismatch of the program?
Prabhu Francis
  • SpaceLYnk
Tags (4)
  • @Thomas_Rohde
  • Erwin-vd-Zwart
  • Thomas_Rohde
Erwin-vd-Zwart
Janeway
Posted: β€Ž2025-09-27 08:15 AM
1
628
@prabhuknx1
There is no attachment and i have 1 super tip..
Just use SE sensors that does not introduce your issue πŸ˜‰ and stay away from the brand you try to use now 😜
Erwin-vd-Zwart
Janeway
Posted: β€Ž2025-09-29 12:28 AM . Last Modified: β€Ž2025-09-29 12:29 AM
@prabhuknx1
For sure automations could help you out here, but why taking this detour when it can be done with a super small 5 line script for all your sensors?
Just create your motion inputs in range xx/1/xxx and your motion output objects in xx/2/xxx and attach to each Motion input object the TAG "Motion" and create a event based script attached to this TAG..
 And insert this script:
locked = grp.getvalue('1/0/0')
if locked == false then
s = string.split(event.dst, "/")
grp.checkwrite(s[1] .. '/2/' .. s[3], event.getvalue())
end
This script will be triggered by any of your motion sensors input object (in range xx/1/xxx), checks if the lock (scheduler) is disabled and sends it's current value to the output object (in range xx/2/xxx), when the lock is enabled it does nothing with the input.
This is way simpler then creating an automation for each and every motion sensor...
Replies 4
Erwin-vd-Zwart
Janeway
1
629
@prabhuknx1
prabhuknx1
Crewman prabhuknx1
Crewman
Posted: β€Ž2025-09-28 07:33 AM
prabhuknx1
Crewman prabhuknx1
Crewman
Posted: β€Ž2025-09-28 07:35 AM
Most we use prefer wired KNX we use MTN630919..Unfornutualy we are using wireless KNX RF that why we some issue on paramaters.
Erwin-vd-Zwart
Janeway
@prabhuknx1
end
Β
