SpaceLynk not discoverable in bacnet explorer after changing IP to different subnet
SpaceLogic KNX Forum
Send InviteCancel
2025-11-2710:28 AM
The SpaceLynk is detectable in Bacnet explorer when using its default IP address (192.168.0.10). However, after changing the device’s network configuration to a different subnet, the device no longer appears in YABE’s BACnet discovery. I can still access the web interface, so IP communication works. It almost seems like the new IP range is being blocked.
