SL & W4K bacnet app very slow
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SL & W4K bacnet app very slow
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2024-01-14 09:57 PM . Last Modified: ‎2024-07-14 11:41 PM
1851
we have 18 area with fancoil bacnet IP with 5 points each to link to KNX.
Every time we try to map a knx adress to an bacnet point it takes 30sec to 60 sec to link it.
I had this issue in the past too on majority of bacnet ip device.
The bad too is that sometimes it fail:
Device with ID = 4002 or its object with ID = 28_5 doesn't exist
Then try again one or two times and then it work....
so 15*5points* 2 times * 1 minute = 150 minute only to link
any idea how to make it faster ? link by script (read/write), update app...
Smarthome & Smartbuilding Expert
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
  • SpaceLYnk
  • Wiser for KNX
domotiqa
Lt. Commander
Posted: ‎2024-10-09 08:19 AM
no. But for next time, someone on a known forum create a script to auto map.
But no, the app should need more stability I guess
Replies 13
Thomas_Rohde
Sisko
Posted: ‎2024-01-15 12:40 AM
Hello Domotiqa,
can you please share more details related to your used device and software status please?
Do you phase the same problems with a W4K as well as with a SL?
Which FW-Version you are using and which version of the App you have installed?
Kind regards
Thomas
Application Design Engineer
domotiqa
Lt. Commander
Posted: ‎2024-01-18 02:48 AM
20210218 client
Spacelynk LSS100200 V2.8.3
As far as I remember, the mapping process was "always" such a pain (at least my 10 last project use).
But in general it s only some point I need.
This time I needed more point and it s horrible. Sometimes I nedd to put the buttun 10 times (error object don't exist) before a press that work and then long delay between 20s to 2 min max...
Sometimes also the discovering don't show all object, need to refresh.
Thks for help
Thomas_Rohde
Sisko
Posted: ‎2024-03-13 06:28 AM
Hello Domotiqa,
I am very sorry but your topic disapeard from my radar. Sorry!
Did you managed in between or is it still open?
Kind regards
Thomas
Neskettani
Administrator Neskettani Administrator
Posted: ‎2024-10-09 07:19 AM
Hello @domotiqa have you found a solution to your problem?
Nesrine Kettani
Marketing owner of Digital Energy Community
domotiqa
Lt. Commander
domotiqa
Lt. Commander
Posted: ‎2025-11-24 08:19 AM
324
in the past i success adding a bacnet exporer in a new tab of the scada main. would be great , so this way we can add a script. because bacnet client is such a pain on each project.... and as explain the old bacnet client integrate in scada main was very quick
Thomas_Rohde
Sisko
Posted: ‎2025-11-24 11:40 PM
Hi Domotiqa!
Is the Spacelogic KNX BACnet Gateway (LSS100300) not suitable for you?
Kind regards
Thomas
domotiqa
Lt. Commander
Posted: ‎2025-11-27 12:07 AM
247
maybe but always hard to sell more product to the customer.
For example another example. here we have a party building for a city in france. All knx+dali+modbus. and 3 HVAC ventilation Thereco (SE as-p each). They give us the bacnet datatable. we can scan devices but someone we need to scan 2,3 or 4 time to see all variable. And it is very time consumming.
After we need to link the bacnet point to knx. I need to press the save buton so many times to link it !! and there is a huuuuuuge delay between each press.
If i use script to map the variable it is very quick (but less easy)... also the scan with the old tabs bacnet was very quick !
Can't you improve it (maybe keep latest point discovererd and add a buton full scan again...) ?
Because once it is mapped no problem it works well..
domotiqa
Lt. Commander
Posted: ‎2025-11-27 01:01 AM
244
also can i have the bacnet lua package ?
Erwin-vd-Zwart
Janeway
Posted: ‎2025-11-27 09:14 PM . Last Modified: ‎2025-11-27 09:19 PM
2
194
@domotiqa
If you have 3 AS-P’s then why do you make the Wiser the client?
You should make it server and use the AS-P as client and make the mapping / bindings in the AS-P side, this is how it’s designed by us.
The BACnet client app is designed for residential so you can onboard a heat pump or airco for example with a total max of 50 points.
The client app is not meant for full HVAC integration on a small building with a higher amount of devices as that slows down the discovery process big time as you now experience..
Erwin-vd-Zwart
Janeway
Posted: ‎2025-11-27 09:23 PM
No, we don’t distribute separate packages, supported features are in the FW or included in our Apps.
All other available packages are unsupported and not publicly shared.
domotiqa
Lt. Commander
Posted: ‎2025-11-27 11:02 PM
190
On most integration, it don't work like that ! Peiople for these kind of Hvac come when they want, put their product, enable BMS communication and leave. Spacelynk is using as server when it is EBO that need KNX point. On building <5000m2, speclynk feat well...
but the bacnet client is a pain ... you say it is for residential only... even on it it is sooo long to use.
Really don't understand why your discover process is so long !!! I ask you why when using the old bacnet tab in scada-main, it is so quick !! Also when mapping with script it is so quick too...
So please, after many message on bacnet client problem,  answer why it is not possible to improve it and make it more quick and stable... Maybe add option to scan/discover new object, but keep in meme the last object discovered....
In this forum, lots of time people explain how to bypass the problem we have on multiple product, despite of fixing our problem.
I have a list from multiple years of problem, change, bug... never fixed.
So please, help Integrator that use SE product since years and are in pain with problem
domotiqa
Lt. Commander
Posted: ‎2025-11-27 11:04 PM
SE blocked so many function usefull in LM product (package install, bacnet ipk, zerotier....). you should make a warning to enbale advanced feature instead of restiction for your installer
