SpaceLynk as BBMD
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLynk as BBMD
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Horacio1
Lieutenant JG Horacio1 Lieutenant JG
Lieutenant JG
Posted: ‎2022-04-19 02:54 PM . Last Modified: ‎2024-07-14 11:44 PM
764
SpaceLynk as BBMD
Can I connect th spacelynk "directly" to an Enterprise Server having the spacelynk as an BBMD???
As always thanks for your support,
Regards
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2022-04-20 08:27 AM
If they are in the same LAN you don’t need BBMD, just give each SL a unique instance ID and discover them in any AS-P or ES..
Erwin-vd-Zwart
Janeway
Posted: ‎2022-04-19 03:31 PM
762
No, SL is a BACnet server that can
subscribe to a BBMD as a foreign device, but why don’t you enable the BBMD in the ES BACnet interface if you need one?
Horacio1
Lieutenant JG
Posted: ‎2022-04-20 08:22 AM
754
I understand; so intead of building something like the picture below, I just "connect" the SL directly to the ES, if the are in the same segment (VLAN or LAN), is that correct?
Erwin-vd-Zwart
Janeway
