Integration 3er party Modbus RTU device to SpaceLynk
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Integration 3er party Modbus RTU device to SpaceLynk
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Horacio1
Lieutenant JG Horacio1 Lieutenant JG
Lieutenant JG
Posted: ‎2022-04-19 08:34 AM . Last Modified: ‎2024-07-14 11:44 PM
1066
Hello Everybody,
I would like to ask you for feedback about an integration I have to do, it is about connecting a Modbus RTU Bosch gateway to an Spacelynk to monitor and control the thermostats of an HVAC system.
I have read the AN027 and I believe I should't have any problems.
Can you share a similar experience?
Thanks for all your help.
HSU
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Documents
  • Protocols
  • SpaceLYnk
Tags (3)
  • modbus
  • spacelynk
Thomas_Rohde
Sisko
Posted: ‎2022-04-19 12:35 PM
Hello Horacio1,
when you went through the AN027 and you feel comfortable to start with it ... YES, go for it.
Important is that you have a registertable of the BOSCH-Gateway so that you can identify the registernumbers and the dedicated sizes and all general modbus settings of this device.
Valuable is of course when you have this Gateway next to you so that you can test it.
As a recommendation ... it is good to select one value which you want to read from this gateway.
Means to start with a small profile with this single value.
If this works ... then you can spent the time to create all the needed registers.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hello Horacio1,
Kind regards
Thomas
