SpaceLogic KNX IP Router and SpaceLogic KNX BMS IP Gateway MTN6500-0103 and LSS100300 read data from different lines
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLogic KNX IP Router and SpaceLogic KNX BMS IP Gateway MTN6500-0103 and LSS100300 read data from different lines
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2025-04-28 05:24 AM
698
Hi
Can I send data from 2 different lines with "KNX Router IP" devices with 1 KNX BMS IP Gateway ?
Or maybe gateway can read data directly from IP routers over IP without line connection ?
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2025-05-23 02:31 AM
Hi Piotr!
I am not sure if I get your point correctly 🤔
Please explain more in detail what you want to achive.
Kind regards
Thomas
Application Design Engineer
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-05-23 10:25 PM
Hi @PiotrJakubczyk
would you like the gateway to work like a KNX/IP router?
Yes, it is capable.
Basically, the routing/tunneling features of the LSS100300 are the same as for LSS100100/200
PiotrJakubczyk
Sisko
Posted: ‎2025-05-26 01:49 AM . Last Modified: ‎2025-05-26 01:52 AM
I want to be sure that I will be able to communicate every way on KNX level, especially:
A<->B,C,D
It is also important to be able to communicate from Z1 to every KNX Line.
Z1 <->A, B, C,D
I'm wondering if LSS100300 (A line) won't be flooded by communication for B,C,D line if I want to make monitoring of every device under B,C,D lines to BACnet/IP. LSS100300 would be so intelligent to route all B,C,D communications directly to BACnet interface?
In MTN6500-0103 I see additional configuration options and KNX network is aware of MTN6500-0103, but I can't add LSS100300 to ETS project so i wonder how it will work
