I was asked by customer to propose to them power supply with diagnostics something like KNX-40E-1280D.
I don't see any of such features in our KNX power supplies (except relay output when there are troubles ), and I wonder what is added value from such feature. If your KNX power supply have problem, everything is offline so you can't verify power supply diagnostics.
Also wonder what is for .knxprod file for our power supplies? (there are no data points or configuration in our PS)
Hello Piotr!
Yes you are correct. We do not have such kind of power supply.
This kind of devices are not only a normal power supply but also a real KNX-Device.
This is necessary to send the dedicated (measured) values like bus current, cabinet temperature etc. on the bus. So they need a dedicated KNX ETS Application.
Hello Piotr!
