Legacy SE Actuator
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Legacy SE Actuator
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
om1301
Crewman om1301 Crewman
Crewman
Posted: ‎2025-05-07 12:09 PM . Last Modified: ‎2025-05-09 03:16 AM
561
Legacy SE Actuator
Updated to Econfigure Expert Version: V2.0.1.16 recently
There appear to be issues with Legacy SE Actuator's in Econfigure Expert not functioning correctly,
MTN648495 - Loads not being allowed to be assigned - Update - Switch 16 Amp can be assigned
MTN649912 - Not Showing up as Selectable in Actuator List in - showing up in List from previous version of Econfigure where the project was originally configured - Loads can be added to this actuator. Also the Legacy MTN649912 Actuator will not export to ETS owing to incompatible BCU Version, assume the ETS file is for the Merten corresponding actuator.
Checked ETS and both in the catalog.
Is there a workaround here in Econfigure or an update to the catalog/Program File that would resolve the issue ?
Cheers
Oliver
  • eConfigure
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-05-13 01:41 AM
1
500
Hello @om1301
good news and bad news.
If you use the latest version of eConfigure Expert, the MTN6499xx actuator is present in the list of available devices, at least in the Italian market, the one I use.
Despite this, the creation of the ETS project generates an unspecified error message.
I assume this needs to be reported to someone dedicated to development
Thomas_Rohde
Sisko
Posted: ‎2025-05-23 02:27 AM
Hello om1301!
Did you reported it towards your local customer care?
Kind regards
Thomas
Application Design Engineer
