SpaceLogic KNX Hybrid Module vs RGB
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • SpaceLogic KNX Hybrid Module vs RGB
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
geir_eas_no_bfo
Lt. Commander geir_eas_no_bfo
Lt. Commander
Posted: ‎2024-12-20 11:51 AM
2025
LSS100400:
I dont understand how to control the RGB lights from a zigbee device.?
There is only  conventional dimmer group adress possibillities??
(It`s working through HUE gatway and a script. (it`s to unstable)
and the point with the Hybrid module is to get rid of all the other gatways)
BR
GIA
  • Wiser for KNX
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2025-01-06 11:34 PM . Last Modified: ‎2025-01-06 11:37 PM
1896
Some devices like GLEDOPTO e27 Lights can be controlled with the library:
When device is inserted, it doesn't have any R,G,B, W or Colour Temperature Variable to get controled, but using the library (direct zigbee command) it is possible.
 or color temperature:
You can try to use library to control this device.
Replies 10
geir_eas_no_bfo
Lt. Commander
Posted: ‎2024-12-26 07:55 AM
okay, I see that this LS100400 only support ELKO++ ;(
--> But Elko does not have RGB dimmers! Is there a workaround by using script through LS100400?
BR
GIA
Thomas_Rohde
Sisko
Posted: ‎2025-01-03 02:27 AM
1934
Hello GIA!
Sorry, but it is not fully clear to me what you are looking for.
One hand you wrote to "how to control the RGB lights from a zigbee device" which means for me, you have a Zigbee Controller or Pushbutton which you want to use to control a RGB-Light within KNX.
On the other hand I guess you try to link a non SE RGB-Lights (Zigbee) with our Hybrid Module to control it from the KNX-World?
Kind regards
Thomas
Application Design Engineer
esteve_budia
Lieutenant
1897
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-01-06 11:49 PM . Last Modified: ‎2025-01-06 11:52 PM
Hi Thomas,
yes I want to use the hybrid module to control zigbee RGB dimmer devices (non SE RGB-Lights (Zigbee) actuators). I have both KNX and zigbee pushbuttons.
Perhaps the soulution Esteve mention, that there is some possibilitis in a library that I should explore.
BR
GIA
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-01-06 11:50 PM
Tanx for the reply 🙂
I will try to explore this function.
BR
GIA
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-10-30 01:36 PM
924
not sure but I did not get this to work! And if this is a "solution" ?
Should it not be a tool to modify the Zigbee Profile ? We need to control Zigbee RGB light in comersial homes and there is also 4 chanel switches that is usful on the market.
BR
GIA
Thomas_Rohde
Sisko
Posted: ‎2025-10-31 01:59 AM
Hello GIA!
When the proposal from Esteve is not working for you then it seems we are not able to support you ☹️
Sorry for that!
Kind regards
Thomas
Erwin-vd-Zwart
Janeway
Posted: ‎2025-11-01 01:27 AM . Last Modified: ‎2025-11-01 01:32 AM
@geir_eas_no_bfo @Thomas_Rohde
Hi GIA (and my friend Thomas 😉),
I assume you use FW 3.0 and i noticed that the script sample above might be holding the wrong location of the Zigbee library as that is changed in the latest FW.
Can you try to change zb = require('applibs.zigbee') into zb = require('applibs.zigbee.zigbee')
You can test the successful load of the library by using log(zb) after its loaded, you should see something like this in the log.
When this is working then i assume the rest of @esteve_budia sample code is also working fine..
Succes!
PS: You can't modify the profiles and there is no tool, that is done for a reason of complexity and that is exactly why we have the script option to open the option to be able to add functionality that is native not supported.
geir_eas_no_bfo
Lt. Commander
Posted: ‎2025-11-06 03:55 AM
it worked fine now with RGB 🙂
Tanx!
I am missing some festures in Touch to set Light Level; Kelvin ?
You use Dimmer slider for this?
BR
GIA
Thomas_Rohde
Sisko
Posted: ‎2025-11-06 11:32 PM
Hello geir_eas_no_bfo!
We do not have such kind of widget yet.
Two options:
1. As you already propose to use a normal Dimmer slider to control the colour temperature via 1Byte instead of 2Byte.
2. You create your own dedicated widget with the help of the widget creator. Attention, custom widget will not appear within the Wiser KNX App.
I would propose you use the widget creator
Kind regards
Thomas
