Sonnenstand
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Sonnenstand
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
baerdo
Crewman baerdo
Crewman
Posted: ‎2025-08-09 02:43 PM
215
Sonnenstand
Hier Code, den ich angepasst habe, um den Sonnenstand in SpaceLYnk zur Verfügung zu stellen:
local function sunposition(latitude, longitude, time)
time = time or os.time()
if type(time) == 'table' then time = os.time(time) end
local date = os.date('*t', time)
local utcdate = os.date('*t', time)
local latrad = math.rad(latitude)
local fd = (utcdate.hour + utcdate.min / 60 + utcdate.sec / 3600) / 24
local g = (2 * math.pi / 365.25) * (utcdate.yday + fd)
local d = math.rad(0.396372 - 22.91327 * math.cos(g) + 4.02543 * math.sin(g) - 0.387205 * math.cos(2 * g)
+ 0.051967 * math.sin(2 * g) - 0.154527 * math.cos(3 * g) + 0.084798 * math.sin(3 * g))
local t = math.rad(0.004297 + 0.107029 * math.cos(g) - 1.837877 * math.sin(g)
- 0.837378 * math.cos(2 * g) - 2.340475 * math.sin(2 * g))
local sha = 2 * math.pi * (fd - 0.5) + t + math.rad(longitude)
local sza = math.acos(math.sin(latrad) * math.sin(d) + math.cos(latrad) * math.cos(d) * math.cos(sha))
local saa = math.acos((math.sin(d) - math.sin(latrad) * math.cos(sza)) / (math.cos(latrad) * math.sin(sza)))
--print("<<<<<<<<<<<< utcdate.hour",utcdate.hour,"utcdate.min",utcdate.min)
--print("<<<<<< sza",sza,"<<<<<< saa",saa)
--print("<<<<< longitude",longitude,"Altitude",math.deg(sza),"Azimuth",math.deg(saa))
return 90 - math.deg(sza), math.deg(saa)
end
local function getSunPos(lat, long, time)
-- calculate UTC altitude and azimuth
local altitude, azimuth = sunposition(lat, long, time)
-- Check previous minute values to detect azimuth direction change 0º and 180º
time = time - 60
local previuos_altitude, previuos_azimuth = sunposition(lat, long, time)
print("previuos_azimuth",previuos_azimuth,"<<<< azimuth",azimuth)
if previuos_azimuth < azimuth then
-- print("<<<<<<<<<<<<< TREND:", "UP")
else
-- print("<<<<<<<<<<<<< TREND:", "DOWN")
end
if previuos_azimuth < azimuth then -- calcualted azimuth trend UP >>>>>>>>>>>>>>>>>>>
if long < 0 then
if lat > 0 then
return altitude, azimuth
else
return altitude, 360 - azimuth
end
else ------------------- long > 0
if lat > 0 then
else
end
end
else -- calcualted azimuth trend DOWN >>>>>>>>>>>>>>>>>>>
if long < 0 then
if lat > 0 then
return altitude,360 - azimuth
else
end
if lat > 0 then
else
end
end
end
end
local plat = 47.53305
local plong = 7.810654
local altitude, azimuth = getSunPos(plat, plong, os.time())
--alert (altitude)
grp.update('32/5/1', altitude)
grp.update('32/5/2', azimuth )
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2025-08-27 01:39 AM
Hallo Baerdo!
Vielen DANK für dieses Skript.
Ich hatte das auch mal erstellt und damit kann man sehr schön in der freien Visu anzeigen wo die Sonne sich gerade befindet.
D.h. mit der Integration eines Satellitenbildes kann man den Azimuth-Wert schön als Strich (Overlay) darstellen.
Man muss nur eine entsprechende Anzahl Bilder beim Wert hinterlegen.
Siehe Beispiel von der Website Sonnenverlauf welche natürlich noch mehr Infos wie Sonnenauf- und Sonnenuntergang als Strich liefert.
Kind regards
Thomas
Application Design Engineer
