Regarding KNX High Bay Sensor (MTN6354-0019) lock command
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Regarding KNX High Bay Sensor (MTN6354-0019) lock command
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Hurr
Crewman Hurr
Crewman
Posted: ‎2024-11-19 08:23 PM
578
Hi Everyone!
We are having an issue with the High bay presence detector MTN6354-0019. The locking command for the detector doesn't work. The detector is configured as High bay 63x4 and using light output for ON/OFF control of lighting circuits. The lock command is linked to the switch input from a Unica Touch panel (MTN6215-0410).
Parameter settings for the detector are attached and looking forward to the solution.
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2024-11-21 12:24 AM
Hello Hurr!
Can you please share a picture of your device (backside)?
Because we have different Firmware-Versions and so it would be needed to understand which version you have.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hello Hurr!
Kind regards
Thomas
