PJLink for Projector Control
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • PJLink for Projector Control
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2024-10-28 04:07 AM . Last Modified: ‎2024-10-28 04:14 AM
746
Hi
I'm trying to control Projector using PJLink and SpaceLYnk or Wiser for KNX?
Found this script but I'm not fluent in scripting and PJLink. Is there way to modify script to get live status of projector as a group address?
require('socket')
value = event.getvalue()
ip = '192.168.1.5'
port = 4352
if value == 1 then
   cmd = '%1POWR 1\r\n'
else
   cmd = '%1POWR 0\r\n'
end
sock = socket.tcp()
sock:settimeout(1)
res, err = sock:connect(ip, port)
if res then
  res, err = sock:send(cmd)
  if res then
    alert('Send OK')
  else
    alert('Send failed: %s', tostring(err))
  end
else
  alert('Connect failed: %s', tostring(err))
end
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2024-10-29 12:44 AM
Hi Piotr!
I assume that your shared script is already working to switch the projector On/Off ... or?
So, of course it is not easy to create/test a script without having the dedicated device next to you.
Based on the shared script I made trial 😉
Please let me know if it works, not works, updates needed etc..
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: ‎2024-11-20 02:42 AM
Hi Piotr!
I am curious ... did it worked?
Kind regards
Thomas
PiotrJakubczyk
Sisko
Posted: ‎2024-11-20 03:12 AM
Yes @Thomas_Rohde it worked, but only as a test...
To have higher confidence, we must wait until the facility's commissioning, which will take place no earlier than a year from now.
